Merged xCloner bans all users from forum
15 years 2 months ago - 14 years 5 months ago #105600 by manburg6
I've updated from 1.6.5 installation to 1.7.
I've notice two issues:
1) all user results as banned
2) I use forum description containing a bbcode table and an icon left-side to each descriprion. All tescription was broken with link "rel="nofollow" target="_blank">" in forum list description.
Any ideas?
Thank you,
Mario
Last edit: 14 years 5 months ago by sozzled. Reason: Change topic icon
15 years 2 months ago #105633 by Matias
1) What does "results as banned" mean in this case? Are they only shown as banned or really blocked from the site/forum?
2) Looks like you have either broken language or template, please try with default template.
Configuration report would be great addition, too.
The following user(s) said Thank You: manburg6
15 years 2 months ago #105693 by manburg6
Yes... sorry for lack of information, I've checked and explain better.
I have Joomla 1.5.22 and Kunena 1.6.4 (strange because when I install the 1.7 version I'm quite sure then installer told me:"update from 1.6.5 to 1.7".
1) All the user are really banned. When one of this try to post a message the answer is "You are banned until today hh:mm" where the hh:mm is the now time. I've translated the error message because my site is in italian and obvously use italian translation
2) Maybe something with language but if I remove image from forum description everything works fine.
If I add table and image using bbcode the error happen. You can see there to the following url(temporary one because it is my test site):
testmwtest . mosquitoweb . it/forum/Lista-dei-forum/
Thanks a lot,
Mario
15 years 2 months ago #105703 by Matias
This is the issue for 2:
<a href="http://<div class="kmsgimage"><img src="http://www.mosquitoweb.it/images/stories/forummodule/bambini.gif" style="max-height:1000px; " alt="" /></div>" rel="nofollow" target="_blank"><div class="kmsgimage"><img src="http://www.mosquitoweb.it/images/stories/forummodule/bambini.gif" style="max-height:1000px; " alt="" /></div></a>
What's your BBCode as HTML doesn't make any sense.
What comes to the banned users, first go to Kunena component and give me Kunena report..
Also can you look into jos_kunena_users table what value does banned field have.
This is a test site? What happens if you recreate it and try to upgrade again, but first uninstalling Kunena (from Joomla NOT from Kunena installer) to remove all potentially modified files.
15 years 2 months ago #105758 by manburg6
In my producuction installation bbcode works fine:
www.mosquitoweb.it/forum/Lista-dei-forum/
Can I substitute bbcode with html?
Kunena report:
htaccess: Exists | PHP environment: Max execution time: 36000 seconds | Max execution memory: 512M | Max file upload: 256M
Joomla default template details : yoo_enterprise | author: YOOtheme | version: 5.5.12 | creationdate: March 2011
Third-party components: UddeIm
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
Modules: Kunena Latest 1.6.4
Banned field of jos_kunena_ has the following value for most of the user: 0000-00-00 00:00:00
The jos_kunena_banned user is empty
I will try to reinstall kunena as you said and update this post.
Thank you
Mario
15 years 2 months ago #105768 by Matias
I suppose that you haven't upgraded your live site yet -- that's very good and saved your day. :)
Let me know what happens when you try to upgrade again.
Time to create page: 0.152 seconds
