Question Rules page problem
(1) You can create a rules page (see How to create a rule and a help page ); or
(2) You can remove the Rules tab from your Kunena menu (see [Merged topic] Edit, hide, disable or translate menu items in K 1.6 (e.g. rules, help, search)
- 56francesco
- Junior Member
I wonder if the Italian forum of assistance to refer joomla what you said, things from nothing ..
I have over 20 thousand to help answer joomla, I would say that I consider to remedy mistakes and that those solutions would arrive there alone.
Furthermore, they do not join the topic with different problems, first read the contents.
Regards.
ps
about this was the response to an alert, the other nothing?
These choices are explained in the two links I posted earlier in this topic.
The two "different" questions that you asked were basically the same thing. I merged them because we can deal with both issues in the same topic. If I have gravely offended you then I apologise but I think you should also try to understand that I have tried to explain the situation to you as best as I can.
- 56francesco
- Junior Member
:ohmy: :ohmy:The two "different" questions that you asked were basically the same thing
:laugh:
- 56francesco
- Junior Member
