Question Rules page problem
- 56francesco
- Junior Member
On the front end of the forum if you select the rules you receive the item whose ID indicated on the back end of the forum
missing checking if the article is public, registered, or special.
I attach images to indicate where the button is experiencing the bg.
- 56francesco
- Junior Member
In the menu of the forum I pointed out the category of AA forum
This category AA contains no content.
If you access the class AA AA menu item the message returned is wrong, you said that you are not authorized to access, but if you log in another way, the message returned is correct.
I attach 2 pictures to help to correct.
- 56francesco
- Junior Member
Of course not, I had written an article for the rules, I left deault ID 1 and testing an article appeared restricted to admin users with login credentials to the test.
But this does not mean that it is a very serious bug in the software and must be resolved as soon as possible now that was accidentally discovered.
Missing code that checks that the item has the attributes public, is not a trifle.
And there is only this lack? I hope so.
Regards.
- 56francesco
- Junior Member
you pasted together two of my topic for two different problems,
and for each I've asked the same question, so I thought I accidentally sent to a double ....
Can you explain why?
