Question Rules page problem
15 years 6 months ago - 15 years 6 months ago #94596 by 56francesco
Bug discovered by chance
On the front end of the forum if you select the rules you receive the item whose ID indicated on the back end of the forum
missing checking if the article is public, registered, or special.
I attach images to indicate where the button is experiencing the bg.
Last edit: 15 years 6 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
15 years 6 months ago #94598 by sozzled
Have you created a rules page for your forum?
15 years 6 months ago #94599 by 56francesco
Error accidentally discovered
In the menu of the forum I pointed out the category of AA forum
This category AA contains no content.
If you access the class AA AA menu item the message returned is wrong, you said that you are not authorized to access, but if you log in another way, the message returned is correct.
I attach 2 pictures to help to correct.
15 years 6 months ago #94600 by sozzled
Replied by sozzled on topic Re: Rules page problem
And I will ask you again: have you created a rules page for your forum?
The following user(s) said Thank You: 56francesco
15 years 6 months ago - 15 years 6 months ago #94602 by 56francesco
Replied by 56francesco on topic Re: Rules page problem
Sorry for the double sending accidental, I do not understand how it could have happened.
Of course not, I had written an article for the rules, I left deault ID 1 and testing an article appeared restricted to admin users with login credentials to the test.
But this does not mean that it is a very serious bug in the software and must be resolved as soon as possible now that was accidentally discovered.
Missing code that checks that the item has the attributes public, is not a trifle.
And there is only this lack? I hope so.
Regards.
Last edit: 15 years 6 months ago by 56francesco.
15 years 6 months ago #94604 by 56francesco
Dear admin
you pasted together two of my topic for two different problems,
and for each I've asked the same question, so I thought I accidentally sent to a double ....
Can you explain why?
Time to create page: 0.145 seconds
