Question Auto Login
15 years 9 months ago #87191 by GoremanX
Replied by GoremanX on topic Re: Auto Login
You'd have much better luck getting the help you need at the JFusion support forum. I've had excellent support from there in the past.
www.friendlyphotozone.com
15 years 9 months ago #87200 by sozzled
Replied by sozzled on topic Re: Auto Login
The solution is actually as simple as changing the site template so that you can use K 1.6 and you won't have to worry about trying to synch users across multiple domains or about adding bridging software (and all the attendant headaches that these can involve) and it only takes a relatively short amount of time to achieve a simple solution. But ... if you really have your heart set on using what you've got then I understand.
Good luck. :)
15 years 8 months ago #88579 by alve26
Replied by alve26 on topic Re: Auto Login
GoremanX wrote: You'd have much better luck getting the help you need at the JFusion support forum. I've had excellent support from there in the past.
i use Jfusion in another website with other forum, but it's NOT compatible with kunena because kunena is a joomla extension and not a separate forum
