Question Auto Login
15 years 9 months ago #86762 by alve26
Auto Login was created by alve26
Hello there,
i would like to enable auto login between a joomla site and kunena forum which is install in a subdomain.
For example my website is build up in www.mysite.com ( in joomla) and kunena is install in www.mysite.com/forum (in a separate joomla installation). I have already connect the 2 databases, so when a user make registration to www.mysite.com then automatically has an account to www.mysite.com/forum . But when i login to the primary site i' m NOT also connectet to the forum.
Does anyone know what can i do to solve the problem?
I make many search to google but there is no bridge between joomla and kunena so i need to make it manual.
Thank you in advance
15 years 9 months ago #86764 by sozzled
Replied by sozzled on topic Re: Auto Login
Kunena doesn't need a bridge. Kunena is not a freestanding product like phpBB or punBB. Kunena is a Joomla extension.
Is there some technical reason that prevents you from installing Kunena in your Joomla website?
15 years 9 months ago #86768 by alve26
Replied by alve26 on topic Re: Auto Login
yes i have problem with jquery in my template and kunena it's not working correctly. i have many bugs (cannot edit profile for example) so it was necessary to install it in a separate joomla ( where i disable j query) and i use it only for kunena :s
15 years 9 months ago - 15 years 9 months ago #86822 by sozzled
We understand that you are having problems using K 1.6 in the way that it was designed. On the other hand, changing your site template is a comparatively easier change to make than the solution that you have proposed.
I am not aware of a solution to your problem. I'm not saying that it can't be solved and, if I were in your situation, I would seriously be weighing up the merits of employing someone to build a solution for me. However I would be asking myself if this was really worth it, too. So, yes, if you would like to know where you might be able to engage professional services to help you I can refer you to a few places but, otherwise, I'm sorry I can't help you.
Last edit: 15 years 9 months ago by sozzled.
15 years 9 months ago - 15 years 9 months ago #86824 by GoremanX
Replied by GoremanX on topic Re: Auto Login
JFusion will allow you to keep 2 Joomla instances synchronized. So logging into one instance of Joomla will log the user in the other instance as well. Also, users created in one instance will also be created in the other.
www.friendlyphotozone.com
Last edit: 15 years 9 months ago by GoremanX.
15 years 9 months ago #87113 by carlton
Replied by carlton on topic Re: Auto Login
I had trouble syncing the two as well. Any helpful walk-throughs online with images? Sorry, I'm trying to learn this on my own.
