- Thank you received: 45
Question system cache plugin + Kunena
This topic is over four years old and relates to issues involving J! 1.5. The J! 1.5 system cache plugin behaviour was very different to the current J! 3.x behaviour.Josh wrote: Any update on this? Seems that Kunena does not play nice with the system plugin on Joomla 3.3.6.
As 810 hinted, if your website content is changing very dynamically—if content is altered many times a minute, for example—you may want to consider disabling the Joomla system cache plugin. If the content on your website is relatively static, you might prefer to enable the Joomla system cache plugin. The choice between enabling or disabling the plugin really is something to be decided on a case-by-case basis.
Could you please explain what you mean by your suggestion that Kunena "does not place nicely" with the System - Cache plugin in J! 3.3.6?Josh wrote: Seems that Kunena does not play nice with the system plugin on Joomla 3.3.6.
0 - DateTime::__construct(): Failed to parse time string ({"year":"1977","month":"7","day":"2"}) at position 0 ({): Unexpected character
It only does this inside of the topic. The index, categories, and search display just fine. I confirmed that this is not a template conflict.
It looks, to me, that this error is not coming from the Kunena component ... but I could be wrong.
I'm guessing that this error message is generated either:
a) part-way through the loading of the topic; or
b) after Kunena has finished processing and Joomla is attempting to load other parts on the page.
In either case, the disturbing factor is that the CSS stylesheet is not properly loading.
To better understand what's going on, the first thing to do is to enable Joomla debug mode and follow the trace-back to see which file is being used at the point when the error message appears.
I'm flying blind here because I don't know much about your website. Even if I saw your Kunena configuration report, I am not sure if I can "remotely diagnose" the problem here, on this forum. I'm willing to give it my best shot, however, but I would be very surprised if the System - Cache plugin was the only thing responsible for this problem.
For your information, I rarely enable the System - Cache plugin—not because I distrust it or fear that it will cause problems but simply because I have no use for it in my websites.
I will enable this plugin on a test site and confirm if K 3.0.6 fails to load pages like it does on your site ... and I will report back soon.
J! 3.3.3 (too many problems with J! 3.3.4, J! 3.3.5 and J! 3.3.6 and I will not be updating Joomla until those problems have [hopefully] been fixed in J! 3.4.0)
K 3.0.6
Joomla Protostar template
Kunena Blue Eagle template
Joomla System - Cache plugin enabled
Global Configuration » System » Cache Settings » Cache = OFF - Caching Disabled
Global Configuration » System » Cache Settings » Cache Hander = File
Global Configuration » System » Cache Settings » Cache Time = 15
No problems detected when viewing categories, topics or posts in topics.
I don't know if this helps or not.
