Question How to add color to a echo command with a variable?
16 years 4 months ago #53451 by iLucato
sozzled wrote: Try this instead:
<?php echo '<font color="#COLORCODE">' . $myvariable . '</font>'; ?>
Mind you, I really hate the use of the <font> tag. Much better to create a <div> or <span> and use CSS to change the colour.
Hey Sozzled, good morning. Thanks for your try too, but it didn't work too. I don't have knowledge about PHP stuffs I move into programming by trial, error, hit and guessing. Well, actually it is among a span tag, but as I don't know how these stuff works I'm not sure if the variable in question would call another style that is overriding this command we put the variable into. As I said, I was trying to change the register link color to be different from all others where the code is:
<span class=""> <?php echo $registration; ?> </span>
Anyway, thanks for your help.
16 years 4 months ago #53452 by iLucato
I tried also to create a stile at the css kunena.forum-min.css file and didn't work. Here is what I did:
At the end of the all styles I added:
#Kunena span.kregisterlink{font-weigh:bold;color:#ff0000;}
and at the PHP code I added in the class the kregisterlink, so it looked like that:
<span class="kregisterlink"> <?php echo $registration; ?> </span>
No success too.
16 years 4 months ago #53461 by @quila
Hi iLucato,
if I understand right you want to change color ONLY for Register link in profilebox.
If that is right you need to do some step, becouse all links are probably already defined in your joomla template and also in kunena.
You can do it in this way:
1. you need to add new class for only that link.
Open the file login.php in /loginbox/ dir. Find that code
<span class="kprofilebox-link"> <?php echo $registration ?> </span>
and replace with this code
<span class="kprofilebox-link k-reg"> <?php echo $registration ?> </span>
as you can see I have added new class "k-reg" only for that link
2. you need to add color for that link in kunena css file
2.1 - open the file kunena.forum.css and add that rule at the end of file
#Kunena div.klink-block span.k-reg a { color: #FF0000; !important; }
3. you need to compress css file
now, if you just put file kunena.forum.css on server will not work becouse kunena use compressed file kunena.forum-min.css if not in debug mode.
3.1 - Go here refresh-sf.com/yui/ and compress kunena.forum.css file, you will have kunena.forum-min.css
3.2 - Now you can put file kunena.forum-min.css on your server and overwrite existing file
That's all.
P.S. If you want to make some change to kunena template, to avoid to do all this step for every change, in the configuration of Kunena set Enable Debug Mode option to "Yes", then you can make all changes you want to kunena.forum.css and kunena will load that file.
One time you have finished to personnalise your template, compress that file like I have described above and turn Enable Debug Mode option to "No".
Hope this helps
Best Regards
16 years 4 months ago - 16 years 4 months ago #54079 by iLucato
Hi @quila.
Ops, I'm sorry for my delay on this one.
Very interesting tip. Thanks a lot. I didn't know this debug feature.
Just one question. As I didn't know it, I have made some changes directly in the compressed file (kunena.forum-min.css). So I think my uncompressed is different now.
Is there a way to do the inverse way?
I mean, decompress to make my "kunena.forum-min.css" become a "kunena.forum.css", so when turning on the debug mode I can have the latest changes I have made. Now a days if I turn it on, I'm not getting my latest lay-out. I think it is due I have changed into "-min" instead. :0)
Last edit: 16 years 4 months ago by iLucato.
16 years 4 months ago #54081 by @quila
16 years 4 months ago #54085 by iLucato
@quila wrote: Yes,
try this one www.lacocina.nl/vrijesoftware/cscssc/css-compressor.html
Great! Thanks a lot buddy. The last question to don't bother you a lot. :0)
Should I use type I or II over there for decompressing? I have no clue what does it stand for. ;0)
Thanks once again.
Time to create page: 0.145 seconds
