Question How to add color to a echo command with a variable?
16 years 4 months ago - 16 years 4 months ago #53432 by iLucato
Hi folks, if I have a code like that
<?php echo $myvariable; ?>
How do I get to make this variable red, green, whatever? I tried to put $myvariable between the tag font color but it didn't work. Surelly I don't know how to connect them.
Any tip?
P.S. it will need to supress/overcome the css style.
Thanks in advance.
Last edit: 16 years 4 months ago by iLucato.
16 years 4 months ago #53434 by Cerberus
another one i can help you with :)
<?php echo "<font color=\"#COLORCODE\"> $myvariable; </font>"; ?>
change COLORCODE to the css color code you wish
16 years 4 months ago #53435 by iLucato
Cerberus wrote: another one i can help you with :)
Hmmm, almost there. There is some error. It shows a semicolon and just the semicolon gets the color and the variable doesn't. I tried to remove the 1st semicolon, but the css style seems to override this command.
Any other comment?
16 years 4 months ago #53436 by Cerberus
<?php echo "<font color=\"#COLORCODE\"> $myvariable </font>"; ?>
Any other comment?
yer sry missed that semi colon, try now
16 years 4 months ago #53437 by iLucato
Yup, as I said before...
So, in sum, didn't work buddy. I was trying to make that moved "register" link you helped me in other thread to be in another color different from the CSS a:link for the all rest.
16 years 4 months ago #53450 by sozzled
Try this instead:
<?php echo '<font color="#COLORCODE">' . $myvariable . '</font>'; ?>
Mind you, I really hate the use of the <font> tag. Much better to create a <div> or <span> and use CSS to change the colour.
