Solved Problems after migration from J! 1.5
in the panel where i define the new category i see this error:
Unknown column 'parent_id' in 'where clause' SQL=SELECT a.id, a.name FROM j25_kunena_categories AS a WHERE parent_id='0' AND id!='0' ORDER BY ordering
And when i try to save, i get this error:
Saving category 0 failed: TableKunenaCategories::store() failed - Unknown column 'parent_id' in 'field list' SQL=INSERT INTO `j25_kunena_categories` (`id`,`parent_id`,`name`,`alias`,`locked`,`accesstype`,`access`,`pub_access`,`pub_recurse`,`admin_access`,`admin_recurse`,`ordering`,`published`,`review`,`allow_anonymous`,`post_anonymous`,`description`,`headerdesc`,`class_sfx`,`allow_polls`,`params`) VALUES ('0','0','Provincia','provincia','0','joomla.level','1','1','1','8','1','99999','0','0','0','0','','','','0','{}')
It doesn't let me save anything.
What's wrong...? :dry:
I do not know what's wrong. I have not encountered a situation like yours before. It sounds like your SQL tables have something wrong. It sounds like you may need to undertake some detailed analysis of your database tables. There are diagnostic tools available in Kunena that may assist you. (Please note that I have not used these tools and I do not know how to interpret the results.) See Diagnostic tool and Database schema tool .d4rkcloud wrote: What's wrong? :dry:
topicMissingCategory TEST FAILED 1 issues
topicMissingMessages TEST FAILED 1 issues DELETE BROKEN ITEMS
messageOrphaned TEST FAILED 25608 issues DELETE BROKEN ITEMS
All the other items are ok!
In the layout scheme i don't see any error.
Should i copy it here?
In short, your response confirms my suspicion that you have problems within the database.
To fix this problem means we need to roll up our sleeves and get involved in some creative database repair work. From the looks of things, you have a missing record in the table _kunena_categories. Because you have a missing record, other records in the database contain references to something that doesn't exist. It's my guess that, using a tool like phpMyAdmin, you could patch the database by re-creating the missing information so that the database integrity is restored. As I am sure you would appreciate, doing this kind of work is outside the "standard" support service we offer here in a "question-and-answer forum". This kind of work is specialised, it's one-on-one and it's time-consuming.
I cannot make any guarantees that I could fix this particular problem for you and I cannot give you a reliable estimate of how much time would be involved, either. I think that we're talking a couple of hours.
What do you have to say to this? Would this be worth paying someone else to look at your current situation to see if it's feasible to rectify the problem you now have? As you know, this time of the year is the holiday season and there may be a shortage of skilled specialists available to assist you. I'm only guessing (I can't say for sure) but I think we're talking less than $100.
I used SPUpgrade and i got the categories, as you can see
here .
The migration was 100% completed and i didn't get any error.
But i can't get any post in the categories.
I changed the permission in every categories so the only thing i miss is the visualisation of the posts.
Just the last step, i think...
P.S.: thank you very much for your support, i really appreciate it!
The users had been correctly migrated ? What Kunena version was used on your Joomla! 1.5 installation ?
You can re-try migration process but only for Kunena: you need to copy kunena tables from your previous Joomla! 1.5 and copy these tables on your new Joomla! installation, then you can launch the installation of kunena 3.0.4 the upgrade process will be done automatically.
