Solved Problems after migration from J! 1.5
12 years 11 months ago #151809 by d4rkcloud
Hi guys,
i'm trying to upgrade a 1.5 site with kunena, i imported all the old tables as writtem here:
webilicious.com.au/kunena-migration
But when i log in, i get these errors:
Table 'namedb.j25_kunena_configuration' doesn't exist SQL=SELECT * FROM j25_kunena_configuration WHERE id=1
Table 'namedb.j25_kunena_user_categories' doesn't exist SQL=SELECT user_id, category_id, role FROM j25_kunena_user_categories WHERE role IN (1,2)
Do you know why...?
Thnks guys and merry Xmas to everyone! :laugh:
12 years 11 months ago - 12 years 11 months ago #151810 by sozzled
G'day, d4rkcloud, and welcome to Kunena.
What tool did you use to migrate from J! 1.5? What version of Kunena are you using now and what version of Joomla are you using now. Have you watched the video vimeo.com/69818669 ?
The short answer to your question is, based on the information you've given us, no, Idon't know why you're getting this error. Sounds like it was a Joomla migration gone wrong to me. :dry:
Last edit: 12 years 11 months ago by sozzled.
12 years 11 months ago #151814 by d4rkcloud
Hi Sozzled,
thanks for answering so quickly!
I installed kunena 3.0.3 in joomla 2.5.17, the old version was the 1.5.6 in joomla 1.5.26.
I used jupgrade and this is the configuration report:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 48M | Max file upload: 32M
Joomla default template details : gantry | author: RocketTheme, LLC | version: 4.1.10 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: CommunityBuilder 1.2.1
Plugins: None
I hope there's everything here....
Thanks!!!
12 years 11 months ago - 12 years 11 months ago #151817 by sozzled
You can't use Community Builder 1.2.1 with J! 2.5.17 and you definitely cannot use CB 1.2.1 with K 3.0.4. Before you do anything else, make a decision to upgrade CB or uninstall it.
Next step is to upgrade to K 3.0.4.
Last of all, get rid of the conflicting Kunena menu item. The FAQs page will show you how to restore the standard Kunena menu.
After you've done those things, you need to go though, category by category, each of you forum categories and fix the permissions; these things should take a couple of hours.
The following user(s) said Thank You: d4rkcloud
12 years 11 months ago #151839 by d4rkcloud
Ok Sozzled, installed CB 1.9.1 and installed Kunena 3.0.4.
The item menu seems to be ok and the previus error vanished.
In the admin panel i don't see any category. Now you say i should fix the permissions, category by category.
You mean in the ftp? where do i find these categories to fix?
My report:
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: CommunityBuilder 1.9.1
Plugins: None
Hope you can help me to handle this!
Thnak you very much!
12 years 11 months ago - 12 years 11 months ago #151850 by sozzled
The biggest problem that people have, after migrating from J! 1.5, is caused by the fact that J! 1.5 did not have ACLs. After migrating from J! 1.5 to any later version of Joomla, you need to use the Kunena Category Manager to reset all the forum section and category permissions again.
This problem is discussed in the topic K 3.0: "There are no published categories in ." message . The answers you are looking for are all there.
Time to create page: 0.180 seconds
