Important Deleting posts doesn't work
16 years 3 months ago #54107 by @quila
Oops, sorry Xilli, didnt see your post ;)
16 years 3 months ago #54112 by barytone
There is none actually! How can it be! Will it work if I download Kunena again and only tranfer the post.php file to my current installation?
Thanks alot!!
16 years 3 months ago #54115 by xillibit
Extract from the kunena the directory template\default et overwrite this directory in your kunena installation.
16 years 3 months ago #54116 by barytone
J'ai essayé, mais je crois ne pas faire ce qu'il faut, puisque ça ne fonctionne pas. J'ai seulement remplacé l'ancien dossier default par le nouveau dossier default.
16 years 3 months ago #54121 by xillibit
Please speak in english, for speak in french it's here : www.kunena.com/forum/24-french
Are-you replaced the direcory with all files and sub-directory ? Do you have still the error :
Warning: include(/home/gameint/public_html/joom/components/com_kunena/template/default/post.php) [function.include]: failed to open stream: No such file or directory in /home/gameint/public_html/joom/components/com_kunena/kunena.php on line 587
Warning: include() [function.include]: Failed opening '/home/gameint/public_html/joom/components/com_kunena/template/default/post.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/gameint/public_html/joom/components/com_kunena/kunena.php on line 587
16 years 3 months ago #54125 by barytone
I don't get an error when I try to delete a post. I get this screen :
With this url : gameinterlude.com/joom/index.php?option=...mid=89&func=post&do= deletetopic&catid=7&id=10
