Important Deleting posts doesn't work
16 years 4 months ago - 16 years 4 months ago #53255 by barytone
Hello everyone,
I'm having an issue when deleting posts. I'm the administrator of the website and when I click delete below a post, it doesn't delete it. Here's a screen-shot of what it does :
So it brings me to that page (for any post I try to delete)
I'm using joomla 1.5.18 and kunena 1.5.12.
Thanks alot for your help!
Frank
My website
www.gameinterlude.com
Last edit: 16 years 4 months ago by barytone.
16 years 4 months ago - 16 years 4 months ago #53262 by sozzled
G'day, barytone, and welcome to Kunena. You have posted a message in our Support category. I have a couple of questions for you but, while we're waiting for your answer, may I suggest K 1.5.x Support: Please read this first. I can't access your website to see anything.
What Kunena template are you using? Do you experience the same issues if you use the unmodified, default_ex template that was included with the Kunena 1.5.12 installation? Thank you. :)
Last edit: 16 years 4 months ago by sozzled.
16 years 4 months ago - 16 years 4 months ago #53364 by barytone
I'm using infinityhu_ex, but I tried to delete posts with default_ex and it gives me the following error:
Warning: include(/home/gameint/public_html/joom/components/com_kunena/template/default/post.php) [function.include]: failed to open stream: No such file or directory in /home/gameint/public_html/joom/components/com_kunena/kunena.php on line 587
Warning: include() [function.include]: Failed opening '/home/gameint/public_html/joom/components/com_kunena/template/default/post.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/gameint/public_html/joom/components/com_kunena/kunena.php on line 587
By the way, deleting threads seems to work!
Thanks alot for your support! :)
16 years 3 months ago #54100 by barytone
Not solved yet :( Anyone could help?
16 years 3 months ago #54105 by xillibit
Do you have checked of the file /home/gameint/public_html/joom/components/com_kunena/template/default/post.php is right here ?
16 years 3 months ago #54106 by @quila
Hi, Frank
seems that you have some files missing in default template (post.php)
To solve the problem reinstall kunena.
Regards
