Question Artio JoomSEF causes problems with Kunena avatars
- David J
I then turned off Artio Joomsef and then everything worked. I could upload, delete, choose from the library etc.
Tunring on Joomsef again(I need good URL's) and changing the Joomsef Kunena extension to'Joomlas default router meant that `i could keep the SEF URL's and Kunens avatars still worked ok though the Kunena URLs are not as SEF friendly.
It was interesting to see that the avatar url changed with Joomsef Kunena extension changed.
This one works
/forums/myprofile/avatar
This one does not work.
/forums/myprofile?do=avatar
Joomsef have just released an update and mentions upgrades to certain plug-ins including the Kunena extension.
I will try this at the weekend (when my site is quieter) and report the results.
Thank you
David J
You might also be interested in the discussion [Merged topic] Kunena and SEO: Why would I need ANY third-party SEF plugin?
- David J
Thank you for the links and information. Turning off the Kunena plug-in from Artio joomsef has cured the problem. I will test their latest version but not yet. I always like to wait a few weeks before upgrading anything.
The merits of an SEF component is down to the individual I suppose. To me it was a great help and I can control every aspect of SEO from 1 area. It also helped with SOBI2 URLs and titles.
I will report back on the lastest upgrade to Artio Joomsef when I upgrade.
Thank you for your help.
David J
I'm using;
Kunena 1.5.12
Joomla 1.5.17
Atio SEF 3.6.2
Tema siteground-j15-101
I have problem with avatar upload.
And also problem with select avatar from avatar gallery.
I think theme is not problem.
Exacly problem from Artio SEF. Because when I disable SEF I can add avatar.But You know in default joomla SEF haven't good links.
If I can do this my website is without problem.
Thanks for your helps from now
Probabyl They don't know answer of this question.
