Question Artio JoomSEF causes problems with Kunena avatars
- David J
First post. I have made my new site live but at the moment a user cannot upload an avatar, or choose one from the default gallery. I have looked through older posts and the archive but not found an answer.
Clicking a radio button or choosing a file to upload results in nothing. There is no error message
I'm using the latest version 1.5.12 and my settings all all correct regarding uploading avatars and allowing choosing from the default library. I'm also using the default template so I'm a bit lost about what to test next.
It worked at some stage because I loaded my own Avatar. Even as a super admin I now cannot change my own avatar.
The site is www.payontime.co.uk
Anything pointers as to what I need to check?
Thank you
David J
Maybe give a test account like that a moderator will test the issue on your site.
You can use
- David J
I have set up a moderator account.
Thank you
David J
I don't know where is exactly the issue, maybe try with default joomla! template to see if you have any differences.
Looks like a lot of complicated script is running on that page that's nullifying Kunena.
- David J
The default template rhuk_milkyway was not present on the www.payontime.co.uk website. I have re-installed it now but it still does not seem make a difference.
Not sure what complicated script is running but it used to work OK. As you can see, my Avatar is there but now I cannot delete it.
I'm happy for someone to access the admin or ftp on the test site to see if there is a problem elsewhere otherwise I don't really know what to do or test.
Thanks for your help so far.
David J
