Question forum/announcement BB code not working when logged in, works when not logged in...
16 years 2 months ago #40797 by bigc90210
trying the same with both width and height operands dont change it either
16 years 2 months ago #40798 by michalu
sozzled wrote:
michalu wrote:
Hi
I have problems with bb code as well. When you are in message editor window none of these buttons work. I cannot add smiles, change fonts or add links.
Has anyone come across any solution?
Kunena 1.5.8, Joomla 1.5.15
I don't understand how your problems are associated with this discussion topic. It sounds to me like your problems are caused by a conflicting Joomla extensions (like RokCandy plugin, for instance) or the Kunena template that you're using.
Thanks a lot! Just unpublished RokCandy and it works now!
I thought this topic was going in other direction, sorry :)
Thanks again!
16 years 2 months ago - 16 years 2 months ago #40802 by bigc90210
Also, something else. It is now seemingly impossible to have images that are also links. for example, if i have [ url=http://www.google.com] and [ /url] around the image, the image is still resized, but no longer linked, and the URL info is displayed as text either side of the image (obviously i put spaces in the code here to show the tags
Last edit: 16 years 2 months ago by bigc90210.
16 years 2 months ago - 16 years 2 months ago #40804 by sozzled
bigc90210 wrote:
The width operand in the quote was actually a size operand? was that a typo?
Yes, I meant size :blush:
bigc90210 wrote:
either way i tried the BBcode which you have suggested, the image has remained the same,
i tried it with width=600, width="600" width=600px width="600px" and the same but with size instead of width, nothing seems to work?
I tried your image on my forum website as I constructed it here
[img size=600]http://www.teamsao.com/images/stories/Promo/L4D2Installer/addon.jpg[/img]
Your image renders like this:
There is a maximum size to which you can go to which is governed by the template you use.
The size setting does change things, as you will discover
bigc90210 wrote:
If this is an intended feature of kunena, maybe it should have a separate tag from IMG as i can see it's an excellent feature for things like uploaded images, but its a nightmare for images pulled from the web, forum sigs, and images you have made specifically to go in the forum head announcement :blink:
I can't say anything about intentions, but this has been standard operating procedure with Kunena for a very long time. It's difficult, I would imagine, crafting a solution to allow a general-purpose forum deliver the functionality to render a broad assortment of different image sizes. Obviously, though, if an image is too large for your forum it will screw everything up, so there have to be compromises made in this department. Some of those compromises involve changing images or template designs. That's all that I can say about the matter. B)
16 years 2 months ago #40805 by bigc90210
the thing is, please try posting that above code into the forum using the account i have gave you, it doesnt work on my forum? both in a forum post, and in the announcements
16 years 2 months ago #40811 by sozzled
As I stated:
You need to experiment, by changing your Joomla template, perhaps by adjusting Kunena configuration settings. Unfortunately, this is about as far as I can go with this support issue.
Time to create page: 0.264 seconds
