Question IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
- iamninjagamer
- Crazyhorse
so big thnx to you for getting me to use this and hope it solves the prob for more then just me.
Greetz Crazyhorse
Just noticed another thing that is not working. Signatures with IMG-tag that points to fbfiles/images shows the bb-code and links to the image.
You may try to change the line 368 at kunena.parser.php
with this one:
Just changing 0 to 1.
This is also useful solution for those who experience problem that img's at signature automaticly link to its source.
replacing kunena.parser.php with the one in the zip file on this thread fixed the image display problem!!
whoop whoop! :laugh:
Just back from my holiday. I am seeing inproper fix for this issue. Actually in Kunena 1.5.5 devs tried to check file extension. Both modifications from users are wrong as they disable this check.
Proper solution is:
/components/com_kunena/lib/kunena.parser.php lines: 345-348
before:Code:$file_ext = explode(',', $params->get('upload_extensions')); preg_match('/\.([\w\d]+)$/', $between, $matches); } if (!in_array(strtolower($matches[1]), $file_ext)) break;
after:Code:$file_ext = explode(',', $params->get('upload_extensions')); } preg_match('/\.([\w\d]+)$/', $between, $matches); if (!in_array(strtolower($matches[1]), $file_ext)) break;
HaND, Jerry
hv a lil problem..i m using cuteftp to chnge php..but i cant see these codes in 345-348.using kunena 1.5.5..missing something..but wht is tht..?
- halo3montage
- Junior Member
Thanks Kunena Team :woohoo:
- RonnyStraetling
don't know whats wrong with my side - there it is still the same issue with 1.5.6. I compared the coding above and it's identical. :S
Any idea?
