Kunena 6.4.13 Released
Question Kunena 1.5.11 , Adjusting the topic width
(1) The overall width of your site template is too narrow!
(2) You have non-effective content in the right hand module position (move it to another module position or remove it completely)
Look at the second image below (ignore the numbers). In your case, the total effective width of evertyhing you display is 1024px. The left module width 205px and the right module width is 205px; that leaves you 614px for the component display. However, these are only raw widths and they don't take into account any left and right padding.
You have 614px to display everything in Kunena! Some of the images on your forum are 400px wide and so they don't fit.
You're using the JA_Purity template (or a slightly modified version of it) which means that this isn't even a Kunena problem! Change the site template width parameters as shown in the following screenshot.
Your website is www.iveedu.com/forum - a completely new installation of Kunena! You should not be using K 1.5.11 for this purpose; we have previously advised that K 1.5.11 is no longer a supported version.
There is nothing on your website, that I can see, that would prevent you using K 1.6.1. For what reason does your client not wish to use K 1.6.1 or (for that matter) a version of Kunena that is supported?
