Question Kunena 1.5.11 , Adjusting the topic width
15 years 10 months ago #71710 by iVeedu
Hello Everybody, This is my first post and not sure whether I posted it in the right place.
Question I have is, How to adjust the width of topic text area? Image attached.
Link: www.iveedu.com/forum/23-video-songs/165-malayalam
Appreciated any help.
15 years 10 months ago - 15 years 10 months ago #71712 by sozzled
G'day, Iveedu, and welcome to Kunena.
I've moved your message to a more appropriate area.
K 1.5.11 is not supported any more. If you must use K 1.5 then please upgrade to K 1.5.13. We recommend K 1.6.1 for new installations.
Useful information for you: Before you ask for help with template issues ... It really helps to look at the tutorial Firebug in the Wiki. I hope this helps.
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago #71714 by iVeedu
Thank u for moving it to the right forum and the tips.
I have installed firebug and found the block of text in css. (image attached) Changed it from 170 to 100 but no luck.. it is not changing the width.
any thoughts/help is appreciated.THANKS
#Kunena td.fb-msgview-left {
background:#EFF0F4;
vertical-align: top;
width:100px;
min-width:100px;
border-bottom: 0px solid #BFC3C6;
border-right:1px solid #BFC3C6;
15 years 10 months ago #71717 by sozzled
Even after you edit the template CSS file and copy the new file to your website (and make sure that you've put it into the right place - see Where is the CSS file? and make sure you read the relevant parts of that article in relation to K 1.5) you may not necessarily see any changes.
This is often caused if you are still using the cached version of the file. Make sure you clear your browser cache first or force a new page refresh.
15 years 10 months ago #71841 by iVeedu
Changed fb-msgview-left width from 170 to 100 and cleared the browser cache but no change in the display!
That probably means I did not change the correct value controlling the width of profile box. Any suggestions on which variable is controlling the width? Any help is appreciated.
Image attached.
Thanks in advance.
15 years 10 months ago #72068 by iVeedu
any help...please
Time to create page: 0.290 seconds
