Kunena 7.0.8 Released
Question Need help with mouse over on Kunena-top
16 years 4 months ago #44137 by Cerberus
#Kunena #fb_topmenu { } #Kunena #Kunena_tab { border 0px 0px 1px 0px; margin:0; top:0; } #Kunena #Kunena_tab ul { margin:0; padding:0; list-style:none; float:left; } #Kunena #Kunena_tab li { display:inline; float:left; margin:0 1px 0 0; padding:0; } #Kunena #Kunena_tab a { /* background: url("images/tabmenuright.gif") no-repeat right top; */ margin:0; padding:0; text-decoration:none; border 0px 0px 1px 0px; float:left; } #Kunena #Kunena_tab a span { display:block; /* background:url("images/tabmenuleft.gif") no-repeat left top; */ border:1px 1px 0px 1px; padding:0 10px 0 10px; font-family:"Segoe UI",Arial,Helvetica,sans-serif; font-size:small; color:#666666; font-weight:bold; line-height:35px; } #Kunena #Kunena_tab a:hover, #Kunena #Kunena_tab li.Kunena_item_active a { background-position:right bottom; } #Kunena #Kunena_tab a:hover span, #Kunena #Kunena_tab li.Kunena_item_active a span { background-position:left bottom; border:1px solid #999999; color:#FFFFFF; font-weight:bold; font-style:normal; text-decoration:none; } #Kunena select, #Kunena select:focus, #Kunena select:hover { background:#F7F7F7 none repeat scroll 0 0; font-size:x-small; border:1px solid #999999; color:#000000; padding: 0px;
i think but id have to see it working and firebug it to be exact..
16 years 4 months ago #44156 by Ninjao
I fixed the issue :)
To make it all fit I edited the Jomsocial template as well as the kunena template. I also switched to Default Ex, and I am heavily editing it to make it match my site.
Saved me a lot of work to just stick to the defaults and edit it myself. Firebug makes the whole process a lot quicker! ;)
Now to get my activity feed to work! :huh:
To people who might stumble upon this post later, take my advice: Download Firebug and stick to all default templates. Use firebug to find where you have to edit the default .css files and you will save yourself a lot of time in the end because the default templates have the best integration with other 3rd party extensions.
I know you might think you are saving time by using a template but in the end you might end up using a lot more time to get your template to work with 3rd party extensions!
-Ninjao
16 years 4 months ago #44158 by Cerberus
i dunno my version of default_ex_dark is just as good as the default_ex one now :P but i agree firebug is ur friend..
Time to create page: 0.238 seconds
