Question Need help with mouse over on Kunena-top
16 years 7 months ago #44082 by Ninjao
Hi guys,
I am trying to customize the comuna3(jomsocial) template to fit to my kunena template. I don't know much about css, I am using firebug to change most of the stuff.
I was wondering if you could tell me how I might change the "mouse over" animation of the kunena forum.
I have copied the buttons (left, right) and already replaced the ones on my kunena theme. However it does not match my comuna3 jomsocial style.
Any ideas?
Thanks in advance!
-Ninjao
16 years 7 months ago #44091 by Ninjao
this is what I would like it to look like (except with the Kunena button text of course)
16 years 7 months ago #44092 by Cerberus
ud have to edit teh kunena template css and add " border 0px 0px 1px 0px; " for normal button and for active button add " border 1px 1px 0px 1px; " and remove any lines that say background-image
16 years 7 months ago #44116 by Ninjao
Ah I see your method would actually have the css draw the borders around the buttons.
The jomsocial template I have uses 2 images, one for the left and one for the right (like the default Kunena template I believe).
I was thinking I would just change the position of the buttons so that the mouse over effect still works.
Do you know how I might do that?
16 years 7 months ago - 16 years 7 months ago #44127 by Cerberus
add to mouse over " border: 1px; and background-colour: #watevercolour u want;" then as u move mouse over u get ur button appear :D much faster than using an image for such a simple button :)
Last edit: 16 years 7 months ago by Cerberus.
16 years 7 months ago #44133 by Ninjao
Ok I was trying to get it to work, and unfortunately havn't gotten it to work! :(
Here is the current css code I have(which I think is relevant to the tabs):
#Kunena #fb_topmenu { } #Kunena #Kunena_tab { margin:0; top:0; } #Kunena #Kunena_tab ul { margin:0; padding:0; list-style:none; float:left; } #Kunena #Kunena_tab li { display:inline; float:left; margin:0 1px 0 0; padding:0; } #Kunena #Kunena_tab a { /* background: url("images/tabmenuright.gif") no-repeat right top; */ margin:0; padding:0; text-decoration:none; border 0px 0px 1px 0px; float:left; } #Kunena #Kunena_tab a span { display:block; /* background:url("images/tabmenuleft.gif") no-repeat left top; */ padding:0 10px 0 10px; font-family:"Segoe UI",Arial,Helvetica,sans-serif; font-size:small; color:#666666; font-weight:bold; line-height:35px; } #Kunena #Kunena_tab a:hover, #Kunena #Kunena_tab li.Kunena_item_active a { background-position:right bottom; } #Kunena #Kunena_tab a:hover span, #Kunena #Kunena_tab li.Kunena_item_active a span { background-position:left bottom; color:#FFFFFF; font-weight:bold; font-style:normal; text-decoration:none; } #Kunena select, #Kunena select:focus, #Kunena select:hover { background:#F7F7F7 none repeat scroll 0 0; font-size:x-small; border:1px solid #999999; color:#000000; padding: 0px;
As you can see I commented out the images, which worked.. except no border :(?
thanks for your help so far!
-Ninjao
