Question Need help with mouse over on Kunena-top
I am trying to customize the comuna3(jomsocial) template to fit to my kunena template. I don't know much about css, I am using firebug to change most of the stuff.
I was wondering if you could tell me how I might change the "mouse over" animation of the kunena forum.
I have copied the buttons (left, right) and already replaced the ones on my kunena theme. However it does not match my comuna3 jomsocial style.
Any ideas?
Thanks in advance!
-Ninjao
The jomsocial template I have uses 2 images, one for the left and one for the right (like the default Kunena template I believe).
I was thinking I would just change the position of the buttons so that the mouse over effect still works.
Do you know how I might do that?
Here is the current css code I have(which I think is relevant to the tabs):
As you can see I commented out the images, which worked.. except no border
thanks for your help so far!
-Ninjao
