Question Column width
16 years 3 months ago - 16 years 3 months ago #50386 by Cerberus
Replied by Cerberus on topic Re: Column width
id put money if you test with rhuk_milkway joomla template the colums would be correct and this is a clash with your custom joomla template.
Last edit: 16 years 3 months ago by Cerberus.
16 years 3 months ago #50393 by sozzled
Replied by sozzled on topic Re: Column width
oorzaak: We could argue this back and forth. It might be a lot simpler if we just keep it simple: let's look at your website. Sometimes we can help and sometimes we can't. We're here to help with Kunena issues but people have to remember that Kunena depends entirely on how users have setup their Joomla installation and so, for that reason, there are some issues that are beyond our scope.
As we always try to remind users, keep to the basics. If you've never used Kunena before: test it; test it on a "vanilla-flavoured" Joomla site; don't change anything ... and I mean anything! Then compare what you find with your experience of this website. As your knowledge, experience and confidence grow then you can experiment with changes.
So, getting back to the original question: you would like to change the width of two columns and you showed a picture taken from this website to illustrate what you mean. As I wrote earlier, if you change the CSS (this can even mean your Joomla CSS) you can affect the column widths of all columns in a table; it's even possible to affect the column widths of all columns on all tables in your website. And so, I would start again, look at your customised Joomla CSS site template, and look for all "width" values there and start disabling them.
16 years 3 months ago #50844 by oorzaak
Replied by oorzaak on topic Re: Column width
Yes, you were right, and so was Cerberus. In the template.css for my Joomla! template it said:
table { table-layout:fixed; }
I remember playing around with this while I made the site (before installing Kunena) but obviously I forgot to switch if off. Now the Kunena layout is ok. Switching it off seems not to affect the rest of the site.
Thanks for your help, Frits
