Question Column width
16 years 4 months ago - 16 years 4 months ago #50069 by oorzaak
Column width was created by oorzaak
Hi, I'd like to change the column width like on this very Kunena forum (see attached screen dump).
I tried to figure it out by myself and I searched this forum, yet I have nu clue.
Specs:
-Kunena 1.5.11
-Joomla 1.5.18
Regards, Frits image missing http://www.kunena.com/media/kunena/attachments/legacy/images/screendump_columns.png
Last edit: 16 years 4 months ago by oorzaak. Reason: - edit: typo in topic subject
16 years 4 months ago #50101 by sozzled
Replied by sozzled on topic Re: Column width
You can change the width of all columns by changing the CSS but I don't think that's what you want to do. In what way, specifically, do you want to change the column width? Do you want the width increased or decreased for example?
You probably can't make the columns any narrower because the width is controlled by the text headings (if you make the heading font smaller, the columns will automatically adjust). The columns will grow wider if the contents is too large to fit.
But, if you want to make the columns a lot bigger, you will need to hack into ../components/com_kunena/template/<your-current-template-name>/listcat.php
<th class = "th-3 <?php echo $boardclass; ?>sectiontableheader" align="center" width="5%"><?php echo _GEN_TOPICS; ?></th> <th class = "th-4 <?php echo $boardclass; ?>sectiontableheader" align="center" width="5%"> <?php echo _GEN_REPLIES; ?> </th>
Change the width values.
16 years 4 months ago #50284 by oorzaak
Replied by oorzaak on topic Re: Column width
Hi, maybe I should have been a bit more specific.
When I installed Kunena, all columns had the same width (which they still have at the moment). See also enclosed screenshot.
I would like to make some columns smaller, for instance the Topics and Replies columns, which only contain numbers. And making those columns smaller, will leave more space for the other columns which contain longer texts. image missing http://www.kunena.com/media/kunena/attachments/legacy/images/kunena_screendump.jpg
16 years 3 months ago #50367 by oorzaak
Hi, I tried this but my columns are still the same width, like in the picture in my post above.
Frits
16 years 3 months ago #50368 by Cerberus
Replied by Cerberus on topic Re: Column width
what templates are you using for kunena and joomla ??
16 years 3 months ago #50384 by oorzaak
Kunena: default_ex
Joomla: I built my own template. I'm afraid the template.css is a bit lenghty to post it here...
Frits
