- Thank you received: 201
Question How do I take out the Topics and Replies columns?
open the file listcat.php, find and comment (or delete)
then do the same with<th class = "th-3> ... </th>
<th class = "th-4 ... </th>
<td class = "td-3> ... </td>
<td class = "td-4> ... </td>
www.damsels.org/index.php/forum/listcat
seems that you have also delete <th class="th-2"> ... </th>
restore this and look if works well.
Do you have that code? As instead of pasting it somewhere else (which I did with the other code) I seem to have deleted it.
Thanks!
insert between th-1 and th-5
