Question How do I take out the Topics and Replies columns?
I've tried removing various lines in listcat.php but have messed it up a bit! I think I must have missed something.
Thanks.
So the question really boils down to "Why do I need to make these changes?"
As I wrote, not very long ago, in another topic - Move "number of replies" :
Some things were meant to be and these two columns (while they consume more space than you would like to allow for them because of the restrictions imposed by your choice of Joomla template) should be left alone.If you want to [make these changes], you will need to modify the PHP files that generate the various lists. These files are located in ../components/com_kunena/template/default_ex. This is a non-trivial issue and I'm trying to answer [the] question as quickly as possible. Unfortunately, to test and prove a solution will take me a couple of hours, which is not a luxury that I can easily afford. Perhaps someone else might be interested in taking your request on-board as a customised hack for you?
Food for thought?
It seems like it those columns were put in there because somebody, somewhere, could count topics and replies, so they did. But we don't need them.
And if I could learn how to do it in this release, then I will be able to replicate it in the next ones. So if anyone can help me with that, it would be great!
Add, to the bottom of you Kunena template CSS, the following lines:
td.td-3, td.td-4, th.th-3, th.th-4 {
display: none;
Someone else may be interested in making these changes for you for a small fee.
