Question Kunena forum width not full
- manansaini
- Junior Member
ans: Kunena1.5.9
What Kunena template are you using?
ans: default_ex
What version of Joomla are you running?
ans: Version 1.5.15
What Joomla template have you installed?
ans: siteground
What is your site's URL. Does your site allow users who are not registered to view your forum? If your site does not allow users to browse your forum pages, do you have a test account that we can use?
ans: www.logicmatters.org
yes you can view even read without register you only need account for post.
These questions (and a few others) were indicated in the reference that given to you earlier.
I hope everything is clear.?
#whitebox div {
text-align:left;
width:auto;
- manansaini
- Junior Member
what about that another problem ?
when i unselect the right and left side bar for forums link then it also hide for articles...
Good. This solves your problem which, by the way, was not a defect of Kunena.hmm thanks a lot sozzled! now its width full!
If you have another problem then please ask it as a separate topic. Your other question might be a simple one, or it could turn into a complex issue. Let's treat the matter separately, shall we, in case other people have a similar issue.
It would also help, for your other problem, to show a screenshot that clearly labels what you call the left and right "side bar". OK?
- manansaini
- Junior Member
i just tested on IE that the right side bar and center content is displaced at the bottom due to the above code ..
before i tested in Firefox in firefox its ok but problem in IE.
I used IE version: 8.0.6001.18882
if i removed that "width=auto;" code then its ok in IE .
Is it OK to close this topic now? :dry:
