Question Kunena forum width not full
- manansaini
- Junior Member
with width=auto; code home page code also change.
- manansaini
- Junior Member
As I told you when I write the code "width=auto;" then only it change the width in IE.
when i delete that line it again works ok...
If you don't change the width value, your Kunena page is affected (the overall width is narrowed); this is caused by the Joomla template. I can say, honestly, that it's not an inherent design flaw within Kunena because if you change your Joomla template then the Kunena display works as you would expect it to. However, changing the Joomla template by adding "width=auto" affects your home page as far as IE 8 is concerned. It seems that you're unable to have it both ways. Whichever way you look at it, it's your Joomla template that's the root cause of the problem and maybe you should take the issue up with the developer of the Joomla template that you are using?
Perhaps your home page problems are the result of a module or plugin or something else that I am unaware of. I offered to look at your website but you have declined. OK, that's your decision and I respect it. I would suggest that you systematically disable all plugins or modules until the display (in IE) works as it's supposed to.
... or perhaps someone else can redesign your website for you. I'm sorry, but I'm out of other options to suggest.
- manansaini
- Junior Member
I think i must have used dedicated forum
Goood luck!
Have a nice day!
Admin!
www.logicmatters.org
