Question Kunena forum width not full
- manansaini
- Junior Member
can u tell me where is the problem>
i tested this on localhost as well on site.
here is screen shot:
img718.imageshack.us/img718/4356/98676389.jpg
if problem due to template tell em where to edit that thing
hope reply u asap.
- manansaini
- Junior Member
plz need urgent solution
- manansaini
- Junior Member
i only want not to display side bar in forums , but want to show in articles
Secondly, you should also read Before you ask for help with template issues ... This may not solve all of your problems but, at least, you will be better prepared for the questions that are about to follow.
Although you have posted a screenshot that illustrates the issue - and thank you for doing that - we cannot provide you with the specific help that you request because everyone's situation is different. Even if you read the countless number of topics that we've dealt with that look similar to what you've got, the solutions may not be appropriate to your specific circumstances.
The solution is, therefore, to use a diagnostic tool like Firebug for Firefox that will pin-point the exact area of your site template that you need to modify.
You can ask for more help if you need it.
- manansaini
- Junior Member
mean if we use kunena template then its the appropriate section. so i have posted in the bugs/technical support/report section.
second i have already read all the posts on this site but not find a appropriate solution one.
i suggest you kindly read again my third post i think its a bug. because only changes in forum also change in other articles.
at least you guys have experience why such problems occur thats why i ask i just need hint where is the problem. I also google a lot but no one similar issue find.
that's why i ask here in the forum.
If your team provide better solution then its appreciate. otherwise i have to switch some dedicated forum
thanks for support.
Very well. Let's assume that your problem caused by Kunena:I have already read all the posts on this site but not find a appropriate solution one.
I suggest you kindly read again my third post i think its a bug ...
What version of Kunena have you installed?
What Kunena template are you using?
What version of Joomla are you running?
What Joomla template have you installed?
What is your site's URL. Does your site allow users who are not registered to view your forum? If your site does not allow users to browse your forum pages, do you have a test account that we can use?
These questions (and a few others) were indicated in the reference that given to you earlier.
