Important Avatar doesn't appear
To begin with, Kunena is a great Joomla component, that is why I chose this to install in my site.
However I encountered a problem I cannot solve, namely, the avatar uploaded doesn't appear.
I have read this thread but didn't find a solution.
www.kunena.com/forum/139-solved-or-prior...it=10&start=30#41175
When I upload the picture, it says file upload was successful, though the avatar doesn't show. I've checked everything in the control panel.
What shall I do?
I use 1.5.9
I post a new message about this here because the other thread is closed now.
The avatar upload and choose avatars from gallery is now working perfect and has propably doing so all time. The problem was to change the permissions to 777 in the right place. I did not realize that the avatar folder was in Joomlas default image folder because i found it on another place in kunena folders (i think it was fb.filedistribution or something like that) and tried to change the permissions there.
So now this is workig fine, i have another problem though, but i will post that one in another thread because it's something total different.
- Joomla version
- Directory and file permissions
- The known issue with K 1.5.9 - there's an extra { located at line 335 of the file ../components/com_kunena/template/default/plugin/myprofile/myprofile_avatar_upload.php
- Integration » Use Pictures from: Kunena | Community Builder | JomSocial
- Joomla template
- Kunena template
- Other Joomla extensions
Therefore, until the cause(s) of these problems has/have been found, we will probably need to investigate each one individually.
Can you please provide the URL and a test account to demonstrate the problem being discussed in this case?
Thank you, stefano, for your contribution. I assume the "other thread" was the one mentioned above: Avatar not showing .I post a new message about this here because the other thread is closed now.
The avatar upload and choose avatars from gallery is now working perfect. The problem was to change the permissions to 777 in the right place.
While it may be a solution to change directory permissions to 777, this is not recommended. It creates a security hole.
In my case I have not experienced the problems that users we are discussing here. I have comfortably been able to use Joomla's recommended directory and file permissions and this has not been a factor in the avatar image upload/display problems involving K 1.5.8 or K 1.5.9. This is not to suggest that, perhaps, changing directory permissions to 777 is not the solution. I just want to warn people that changing directory permissions in this way [to 777] may increase your site's vulnerability to unauthorised access.
Perhaps there's a different common denominator, morfina. Perhaps the cause of your problem lies outside Joomla/Kunena. Perhaps the problem lies with the webhosting platform.I reinstalled joomla and kunena (My only component in the site) and the error is the same...
What webserver software is being used?
PHP version?
Can you reproduce these problems on a different webhost? For example, if you were to create a copy of your site on your own PC - using WAMP or XAMPP - are the problems reproduced?
