Important Avatar doesn't appear
16 years 7 months ago #41237 by morfina
Replied by morfina on topic Re:Avatar doesn't appear
Realy a big THANK YOU sozzled for solving the problem. :)
16 years 7 months ago #41263 by Victorius
Replied by Victorius on topic Re:Avatar doesn't appear
sozzled wrote:
Can you please provide the URL and a test account to demonstrate the problem being discussed in this case?
I can, but the forum is in Hungarian, I'm not sure if you understood even a word. :cheer:
16 years 7 months ago #41264 by Victorius
sozzled wrote:
This is not a "normal" setting; this is not even a recommended setting but it is a solution to the problem. This seems to suggest that there is something defective in the background.
Before I switched off the image processor option I hadn't even been able to upload any pics. With an error message I'd been refused.
I switched it off then the avatar uploads were successful, though they didn't show. :S
16 years 7 months ago #41278 by Victorius
I am getting nuts! I have checked and tried everything - same result. If I upload any of the default avatars they are shown, but if I try to upload an avatar from my pc, it says upload was successful, but not avatars are shown. :S :S :S
I even tried to replace the php file with the one you submitted, but it resulted in more php error messages. (Interestingly the content of that php file and the one comes with my installation archive is pretty different in a lot of rows!)
I feel desperate becaues it should work, but it doesn't. I have spent so many hours working on it and I don't know what to do. :(
16 years 7 months ago #41291 by sozzled
Replied by sozzled on topic Re:Avatar doesn't appear
Victorius: Please read carefully what I wrote in message #41205 earlier. There are several issues mentioned in that message. We can add the "Image Processor" GD2/GD1 issue to that list, too.
You say you have checked "everything". For each of the dot-points listed in message #41205 , what are your responses?
What were the PHP errors? What version of PHP are you running? There is only one difference (at line 335, there is one less { )
16 years 2 weeks ago #62627 by abasel
Replied by abasel on topic Re: Avatar doesn't appear
I've tried all the processor options.... none worked.
I got no error messages but the imaged didn't appear to upload either
