Question 1.5.7 installation
17 years 6 days ago - 17 years 6 days ago #33424 by Milutin
Replied by Milutin on topic Re: 1.5.7 installation
Matias wrote:
So it's a permission problem in Joomla. Kunena installer installs files only to three locations:
components/com_kunena
administrator/components/com_kunena
images/fbfiles
Unfortunately there's no way to tell which file fails to install, as copying of the files is handled by Joomla, not by Kunena.
/api folder isn't copied as it is empty, so you should not worry about it. All the other files should be located in previous locations.
I had the same problem
installation trough joomla install with permission 777 and got the following:
-1 - Pojavila se greška Nije moguće kopirati izabranu datoteku Call stack # Function Location 1 JAdministrator->dispatch() /home/gradbije/public_html/administrator/index.php:67 2 JComponentHelper->renderComponent() /home/gradbije/public_html/administrator/includes/application.php:136 3 require_once() /home/gradbije/public_html/libraries/joomla/application/component/helper.php:162 4 JController->execute() /home/gradbije/public_html/administrator/components/com_installer/admin.installer.php:44 5 InstallerController->doInstall() /home/gradbije/public_html/libraries/joomla/application/component/controller.php:236 6 InstallerModelInstall->install() /home/gradbije/public_html/administrator/components/com_installer/controller.php:71 7 JInstaller->install() /home/gradbije/public_html/administrator/components/com_installer/models/install.php:86 8 JInstallerComponent->install() /home/gradbije/public_html/libraries/joomla/installer/installer.php:332 9 JInstaller->parseFiles() /home/gradbije/public_html/libraries/joomla/installer/adapters/component.php:161 10 JInstaller->copyFiles() /home/gradbije/public_html/libraries/joomla/installer/installer.php:642 11 JFolder->copy() /home/gradbije/public_html/libraries/joomla/installer/installer.php:931 12 JFolder->copy() /home/gradbije/public_html/libraries/joomla/filesystem/folder.php:113 13 JError->raiseError() /home/gradbije/public_html/libraries/joomla/filesystem/folder.php:122 14 JError->raise() /home/gradbije/public_html/libraries/joomla/error/error.php:171 15 JException->__construct() /home/gradbije/public_html/libraries/joomla/error/error.php:136
Kunena works but there is a warning on every page of joomla:
error while loading data!
Now I have this warning even if I uninstall kunena and confirm that all files are deleted trough FTP
www.gradbijeljina.com/forum
Last edit: 17 years 6 days ago by Milutin.
17 years 6 days ago - 17 years 5 days ago #33442 by Milutin
Replied by Milutin on topic Solved
Ok I managed to do the instalation without the error at the end but i still have the warning on all joomla pages :
Error while loading data!
(solved) What are the odds that at the same time of kunena installation there is a problem with RSS sidicator which created the warning massage - who would think of that!
Last edit: 17 years 5 days ago by Milutin.
