Question 1.5.7 installation
17 years 1 week ago - 17 years 1 week ago #33096 by mumins
1.5.7 installation was created by mumins
I uninstall 1.5.4, then install 1.5.7. (com_kunena_v1.5.7_stable_b1851_2009-11-18.zip ) through Upload Package File.
Apache/1.3.41 (Unix) PHP/5.2.8 with Suhosin-Patch Mysql/5.0.67
J1.5.14 permissions/max uplad size/memory limit/safe mode off/ ok
With enabled debug i got:
Joomla show Kunena in Extension Manager Kunena - 1.5.7 2009-11-18 www.Kunena.com .
Well - forum is runing, but i'm not sure, that everything is OK.
MBR
m.
P.S.
Looks like it's my joomla installation problem - but any guidelines?
Last edit: 17 years 1 week ago by mumins.
17 years 1 week ago #33177 by Matias
Replied by Matias on topic Re: 1.5.7 installation
Lets try the same with older versions.. Uninstall and install K1.5.4. What happens?
Then try to install K1.5.7 without uninstalling first.
17 years 1 week ago #33251 by mumins
Replied by mumins on topic Re: 1.5.7 installation
Well, i uninstall 1.5.7 then try install 1.5.4 and 1.5.6.
Same error.
Kunena version history:
Started with 1.0.9 then upgrade to 1.5.4 and now - 1.5.7.
Other Joomla components instals without any problems.
As i said - forum runing well, kunena admin said - version 1.5.7.
8=@
If this error said witch file isn't copyed - this will helps.
For example - in install package is empty folder api - but i cant see it on server.
There is file listings
File Attachment:
File Name: lala.txt
File Size:13.49 KB
17 years 1 week ago #33255 by Hurr1c4n3
Replied by Hurr1c4n3 on topic Re: 1.5.7 installation
And if you uninstall kunena 1.5.7 and then check with a ftp-client if alle kunena files/folders are gone. Are they gone? If not. Delete them all en try to install kunena 1.5.7 again. Allways backup first!
17 years 1 week ago #33280 by Matias
So it's a permission problem in Joomla. Kunena installer installs files only to three locations:
components/com_kunena
administrator/components/com_kunena
images/fbfiles
Unfortunately there's no way to tell which file fails to install, as copying of the files is handled by Joomla, not by Kunena.
/api folder isn't copied as it is empty, so you should not worry about it. All the other files should be located in previous locations.
17 years 1 week ago #33312 by mumins
Of course was gone.
images/fbfiles
Hmm, looks like that was a problem, sorry for my panic.
Try to test tomorrow.
MBR
m.
