Question move users and posts from fireboard j1.0 to Kunena J1.5
16 years 9 months ago #24964 by dave80
I have the following componemnts:
JForms 0.6 RC1
JomComment 3.0 Build 562
jPFChat 2.0.2
My Blog 3.0 Build 323
SimpleCalendar 0.7.9b
16 years 9 months ago #25011 by sozzled
dave80 wrote:
I have the following components:
JForms 0.6 RC1
jPFChat 2.0.2
These components on both sites? You also have Community Builder V? installed on one or both sites, too?
My point is this: I was talking only about copying the SQL tables associated with Kunena. These tables (normally) have the prefix jos_fb_ ... you should not export other tables, particularly if you are running different versions of the components that work with them. In your earlier message you wrote:
I followed the steps above and after importing the jos_fb files got the following error:
Error
SQL query:
-- Dumping data for table `jos_comprofiler_lists`
jos_comprofiler_ tables are used by Community Builder. That is what the error message was about. You will need to upgrade CB to CB 1.2.1 when you upgrade to K 1.5.4!
I don't remember exactly the table names in K 1.0.8 (it was a long time ago). The K 1.5.4 tables are called:
jos_fb__announcement
jos_fb_attachments
jos_fb_categories
jos_fb_config
jos_fb_config_backup
jos_fb_discussbot
jos_fb_favorites
jos_fb_groups
jos_fb_messages
jos_fb_messages_text
jos_fb_moderation
jos_fb_ranks
jos_fb_sessions
jos_fb_smileys
jos_fb_subscriptions
jos_fb_users
jos_fb_version
jos_fb_whoisonline
Export whichever tables of the above-named that you have (and you may not have all of them, either) but only these!
16 years 9 months ago #25037 by dave80
CB was only in 1.0
I tried to unistall and try again and now get this error
Error
SQL query:
-- -- Dumping data for table `jos_fb_categories` -- INSERT INTO `jos_fb_categories` (`id`, `parent`, `name`, `cat_emoticon`, `locked`, `alert_admin`, `moderated`, `moderators`, `pub_access`, `pub_recurse`, `admin_access`, `admin_recurse`, `ordering`, `future2`, `published`, `checked_out`, `checked_out_time`, `review`, `hits`, `description`, `headerdesc`, `class_sfx`, `id_last_msg`, `numTopics`, `numPosts`, `time_last_msg`, `smf_category_id`, `smf_board_id`, `smf_board_parent_id`) VALUES (1, 2, 'Certificate III in Fitness', 0, 0, 0, 1, NULL, 18, 0, 25, 0, 2, 0, 1, 0, '0000-00-00 00:00:00', 0, 0, 'Discussions for all Certificate III in Fitness topics.', '', '', 169, 65, 91, 1247999089, 0, 0, 0), (2, 0, 'Certification Courses', 0, 0, 0, 1, NULL, 18, 0, 25, 0, 1, 0, 1, 0, '0000-00-00 00:00:00', 0, 0, '', '', '', 169, 73, 93, 1247999089, 0, 0, 0), (3, 2, 'Certificate IV in Fitness', 0, 0, 0, 1, NULL, 18, 0, 25, 0, 3, 0, 1, 0, '0000-00-00 00:00:00', 0, 0, 'Discussions for all Certificate [...]
MySQL said: Documentation
#1054 - Unknown column 'smf_category_id' in 'field list'
16 years 9 months ago - 16 years 9 months ago #25043 by sozzled
Have you performed the steps as I originally stated them? There look to be references to SMF (Simple Machines Forum) - the grandaddy of all forums - which do not appear (to my limited knowledge) in the versions of Kunena that I'm familiar with. Now that you have informed us of the added complication involving an ancient version of Community Builder, this is my revised general procedure:
  1. Make a copy of of your original Joomla 1.0.15 website using the appropriate version of Joomlapack.
  2. Using the copied version of the original website (I assume you know how to use Joomlapack and kickstart.php), completely remove Community Builder from your website.
  3. Upgrade from Fireboard to Kunena on the "copied" site. Please make sure you understand the upgrade process first! You have not stated what version of Fireboard you were using. Please search the forum for specific instructions on how to upgrade Fireboard (I suspect this is what has caused your latest problems). Please understand that I am only giving you a very general process description.
  4. Uninstall Fireboard; Kunena will not operate with Fireboard installed. Before doing anything else, make sure that your old Fireboard-now-Kunena website works properly!
  5. Uninstall any old versions of Kunena and Fireboard from your J! 1.5 site; if necessary, DROP all jos_fb* tables from your new J! 1.5 site. Kunena will not operate if Fireboard is installed. Install K 1.0.11 on your new Joomla 1.5 website.
  6. Install Community Builder 1.2.1 - do not install any other version of CB on your J 1.5 website! This is important!
  7. Ensure that your new J! 1.5 site now operates with Kunena 1.0.11. Make a Joomlapack backup of your new site.
  8. Export the jos_fb* tables from your upgraded website and import them into your new site database.
  9. Upgrade to K 1.5.4 on your new J! 1.5 website.
Last edit: 16 years 9 months ago by sozzled.
16 years 9 months ago #25095 by dave80
I performed the steps above and now I get the following error......
Error
SQL query:
-- Dumping data for table `jos_fb_groups`
INSERT INTO `jos_fb_groups` ( `id` , `title` )
VALUES ( 1, '"._FB_REGISTERED."' ) ;
#1062 - Duplicate entry '1' for key 1
16 years 9 months ago - 16 years 9 months ago #25099 by sozzled
As I have continued to write, I am looking at your situation in general terms (and I'm making a lot of educated guesses into the bargain) because I am not personally 100% fluent with the whole Fireboard -> Kunena migration plus Joomla 1.0 -> Joomla 1.5 process. I mean, I have done these things ... but not all at the same time as you are trying to do.
You might also like to read SOLVED. Migrating from J! 1.0.x & Fireboard 1.0.x to J! 1.5.x & Kunena 1.5.x posted only a short while ago.
At what step in the "procedure" (see #25043 ) do you now receive these new SQL error messages? It would help to know how you went with each of the steps I wrote about, too.
Time to create page: 0.224 seconds
