Question move users and posts from fireboard j1.0 to Kunena J1.5
16 years 9 months ago #25110
by dave80
Replied by dave80 on topic Re:move users and posts from fireboard j1.0 to Kunena J1.5
I appreciate you r help so far.
I received the error message at this stage.
8. Export the jos_fb* tables from your upgraded website and import them into your new site database.
16 years 9 months ago - 16 years 9 months ago #25111
Replied by sozzled on topic Re:move users and posts from fireboard j1.0 to Kunena J1.5
Thank you for the update. I assume - this is a massively big assumption - that you stopped, checked and verified the success of each of the preceding seven steps.
Assuming that you have made a viable backup at step 7, this is what I would do in your present situation:
- Restore your backed-up (Joomlapack) website - the one you created at step 7 (that's why I recommended you do it).
- Verify (again) that you have Kunena 1.0.11 on the restored website
- Logout of the "restored" website
- Leave untouched Kunena's files but DROP all jos_fb_* tables associated with the new site
- Now that you have no possibility of "duplicate" tables, records and/or indexes, import the jos_fb_* tables that you had from the J! 1.0.15 website that you've converted to K 1.0.11 (in step 3 of my last-revised procedure)
- Login to your new J! 1.5 website and confirm that all the messages you've had are now moved across.
- Now you can consider upgrading to K 1.5.4.
Last edit: 16 years 9 months ago by sozzled.
16 years 9 months ago #25112
by dave80
Thanks again.
Will give it a try....fingers crossed
16 years 9 months ago #25123
by dave80
Success. Thanks alot for your help. You last steps worked and I had to add jos_fb_categories now it is all good.
Thanks again
Thanks again
Time to create page: 0.264 seconds
