Question move users and posts from fireboard j1.0 to Kunena J1.5
16 years 9 months ago #24567
by dave80
move users and posts from fireboard j1.0 to Kunena J1.5 was created by dave80
Is there a way to move all users and posts from Fireboard on Joomla 1.0 to Kunena on Joomla 1.5
thanks in advance
thanks in advance
16 years 9 months ago #24591
Replied by sozzled on topic Re:move users and posts from fireboard j1.0 to Kunena J1.5
G'day, dave, and welcome to the forum. I think you'll find the following discussion helpful
Upgrade from joomla 1.0.15 / fireboard 1.0.4 to joomla 1.5.12 / kunena 1.5.3
. The short answer is, yes, there is a way to achieve your requirement!
16 years 9 months ago #24594
by dave80
Replied by dave80 on topic Re:move users and posts from fireboard j1.0 to Kunena J1.5
These are 2 separate sites (no migration occured) is it still possible?
16 years 9 months ago - 16 years 9 months ago #24596
Yes, it's quite easily achieved. I've inferred (from your response) that you have two working websites. One site is running Joomla 1.0.x that has an unspecified version of Fireboard and the other, new, site that is running Joomla 1.5.x without any version of Kunena installed. Am I correct?
This is the general migration procedure I would use:
- On the original website, migrate and/or upgrade to Kunena 1.0.11. Alternatively, make a copy of this website using Joomlapack and perform the steps on the "copied" site.
- Install K 1.0.11 on your new Joomla 1.5 website
- Export the jos_fb* tables from your upgraded website and import them into your new site database
- Upgrade to K 1.5.4
Last edit: 16 years 9 months ago by sozzled.
The following user(s) said Thank You: Goliath
16 years 9 months ago - 16 years 9 months ago #24928
by dave80
I followed the steps above and after importing the jos_fb files got the following error:
Error
SQL query:
-- Dumping data for table `jos_comprofiler_lists`
INSERT INTO `jos_comprofiler_lists` ( `listid` , `title` , `description` , `published` , `default` , `usergroupids` , `useraccessgroupid` , `sortfields` , `filterfields` , `ordering` , `col1title` , `col1enabled` , `col1fields` , `col2title` , `col2enabled` , `col1captions` , `col2fields` , `col2captions` , `col3title` , `col3enabled` , `col3fields` , `col3captions` , `col4title` , `col4enabled` , `col4fields` , `col4captions` )
VALUES ( 2, 'Members List', 'my Description', 1, 1, '29, 18, 19, 20, 21, 30, 23, 24, 25', 18, '`username` ASC', NULL , 0, 'Image', 1, '29', 'Username', 1, 0, '42', 0, 'Other', 1, '26|*|28|*|27', 1, '', 0, '', 0 ) ;
MySQL said: Documentation
#1062 - Duplicate entry '2' for key 1
What does this mean??? Where to from here???
Any help greatly appreciated.
Error
SQL query:
Last edit: 16 years 9 months ago by dave80.
16 years 9 months ago #24931
This problem looks to be concerned with the Community Builder component. You didn't mention that you had Community Builder installed on either site. It also sounds like you exported more than just the jos_fb* tables in step 3 above.
What is the current situation with your new J! 1.5.x website? What components (and what versions of those components) have you installed?
Time to create page: 0.255 seconds
