Question Moving forum to another menu
16 years 7 months ago #44472 by Cerberus
try using rhuk_milkyway template see if it a template issue.
16 years 7 months ago #44492 by sozzled
G'day, Omar, and welcome to the forum.
There's just one small matter that I'd like to remind you about (and to help other new members of this site) before we get started:
    The
Support category, where you posted your question, is intended to be used to address problems with the unmodified core Kunena software - not to ask how to change it or to discuss problems you are encountering with third-party developed features - or to report defects that you are have found - not to ask questions about how to use the software normally or how to use Joomla normally. We give these support topics higher priority than other topics, particularly around the time when there is a new release of Kunena (as there was only a couple of days ago), in order to ensure that defects are not passed on to other users. I have moved your topic to a more appropriate section.Above all, when asking for support we can only help you if you are using the latest, unmodified stable version of Kunena. This is currently K 1.5.11.
You may choose to stay with an old version of Kunena, if you wish, but you will have to sort out those problems yourself. However, in this case, it seems as though we are discussing a fairly basic Joomla function that has really has very little to do with Kunena. Does that sound about right? You probably should delete your current menu item for Kunena and create a new one.
Menu assignment problems may be affected by the use of Joomla SEO or a third-party SEO/SEF product like sh404SEF. Are you using anything like this?
What is "teline III" for Joomla? I have never heard of it.
16 years 7 months ago - 16 years 7 months ago #44494 by Cerberus
its a joomla template bro :P
example of teline:
Last edit: 16 years 7 months ago by Cerberus.
