Question Moving forum to another menu
16 years 7 months ago #44408 by Omar AlAnsari
Hi All,
We have recently installed kunena which we really like and appreciate the effort put into it.
When we first installed it we have created a menu link which was a submenu under jomsocial
- community
-- Forum
However now we would like to move it to be working as a separate main link
- Forum
When we simply do the change in the menu nothing actually works and the links all point to an error page
We would really appreciate the help on how we can go around this without breaking any links.
Regards,
Omar
16 years 7 months ago #44413 by Cerberus
add this as a menu link
index.php?option=com_kunena
and it should work
16 years 7 months ago #44442 by Matias
I have not tried this, but there seems to be Alias type, which can help you to keep both links working. I have never used it, so I have no idea how it works..
If you want to add redirect, I believe that there are only two ways to do it: either you add redirect rule into .htaccess (Apache file) or you find a plugin/component which redirects URL for you.
16 years 7 months ago #44456 by Omar AlAnsari
I am not sure if i made my self clear ..
I am not trying to keep old links working .. I am not getting the new menu links to work ... when i create a new menu item which links to the forum it works just fine ..
but when I click in one of the forums or subforums it take me to the "page not found" page ..
would appreciate the help .. i think there might be something else to it .. i just found out that i can't even move another menu item and not just the forum .. I just tried moving a contact us form from one place to another and it does not function in the new place.
16 years 7 months ago - 16 years 7 months ago #44460 by Cerberus
what version of joomla kunena are you using and what templates are you using on both ??
Last edit: 16 years 7 months ago by Cerberus.
16 years 7 months ago #44464 by Omar AlAnsari
I am using
Joomla 1.5.15
Kunena 1.5.9
I am using teline III for joomla and default_ex for Kunena
