Question Possible to allow guest to post
15 years 4 months ago #100148 by sozzled
This topic was started 15 months ago and relates to K 1.5. The advice given then applies to that version and does not apply to K 1.6 which has changed this operation in many significant ways. I think this topic has served its usefulness and should be considered closed.
The topic has been locked.
15 years 4 months ago #100150 by mstephan
Sorry >.< I didn't look at post dates.
15 years 4 months ago - 15 years 4 months ago #100175 by otips
Cheers.
But I am none the wiser, despite exhaustive searches within these boards.
Our boards are open to Everyone to read, so setting public access to registered only would delimit this. Is there a way to do this at the forum category/section level? Even through custom code.
Last edit: 15 years 4 months ago by otips.
15 years 4 months ago - 15 years 4 months ago #100220 by sozzled
otips: You posted your question in a topic that was was started 15 months ago that related to a release of K 1.5 that is no longer supported. The advice given then applies to that version and does not apply to K 1.6 which has changed this operation in many significant ways. We recommend that all users of K 1.5.x should upgrade immediately to K 1.6 to fix the problems that were involved in that older version.
thegenni wrote (15 months ago):
Is it possible to allow guests to post without registering?
The short answer to that question is yes - in both K 1.5 and in K 1.6 - and xillibit answered that question.
otips wrote:
Is is possible to Allow guest post/write privileges at the category level?
This is a different question but the short answer is, again, yes. Implementing the solution may be different depending on what version of Kunena people are using.
Let us be clear that, if people are using K 1.6, people should not resurrect old K 1.5 topics because other people, who also use K 1.6 and who may want to know the answer, will not find their answer by looking in the K 1.5 forum categories.
What version of Kunena are you using?
Last edit: 15 years 4 months ago by sozzled.
15 years 4 months ago #100230 by otips
Thanks Sozzled and my error for delving into the archive, which I now realise.
We are on Kunena 1.6.4
Thanks,
Oisin
15 years 4 months ago - 15 years 4 months ago #100235 by sozzled
Thank you. You see the dangers of resurrecting old topics? I'm locking this topic to prevent further confusion.
Let's start again by reading
  1. Sections, Categories, sub-categories (part 1) ; and
  2. Sections, Categories, sub-Categories (Part 2) - advanced setup for special groups
Even though the information in those articles needs revision, if these do not answer your question, please create a new topic in the K 1.6 Common Questions category.
