Question Possible to allow guest to post
16 years 8 months ago #42798
by thegenni
If you are danish, you should really check out my It Forum . Otherwise you might not understand my language... But check the design anyway
Possible to allow guest to post was created by thegenni
Hi
Is it possible to allow guest`s to post without registrering?
The topic has been locked.
16 years 8 months ago #42801
by xillibit
Replied by xillibit on topic Re:Possible to allow guest to post
It's possible, just configure this in backend, in kunena configuration panel : Public Read/Write .
16 years 8 months ago #42830
by thegenni
Replied by thegenni on topic Re:Possible to allow guest to post
Ok, thanks. BUT
I cant see the "Create Post" button.
I`ve got this line that displays:
Deprecated: Assigning the return value of new by reference is deprecated in C:\wamp\www\components\com_kunena\kunena.php on line 698
Im running the newest wamp server
16 years 8 months ago #42839
Replied by sozzled on topic Re:Possible to allow guest to post
The "deprecated PHP warnings" - a side-effect of WAMP - has been discussed several times in this forum. Here are some
search results
for topics that handle these issues.
thegenni wrote:
thegenni wrote:
I assume that we've answered your "guest posting" question? :dry:Ok, thanks. BUT ...
15 years 4 months ago - 15 years 4 months ago #100141
by otips
Replied by otips on topic Re: Possible to allow guest to post
Hi All,
Is is possible to Allow guest post/write privileges at the category level? I would like to create one category where guests can post to try our support boards before they register and set review posts = yes, so as to minimise rule violation.
I think this would encourage more people to register.
O
O
Last edit: 15 years 4 months ago by otips.
15 years 4 months ago - 15 years 4 months ago #100147
by mstephan
Replied by mstephan on topic Re: Possible to allow guest to post
Hmm..I'm pretty sure the ability for guests to post is currently a forum-wide setting. Perhaps you could activate this and set the public access to registered for any boards you do not want guests to be able to post in? You can set review posts to any category you wish in the Category Manager.
Last edit: 15 years 4 months ago by mstephan.
