- Thank you received: 566
Kunena 7.0.8 Released
Question Remove menu, breadcrumb and link directly to specified cathegory
16 years 11 months ago #27862
by Matias
Replied by Matias on topic Re: Remove menu, breadcrumb and link directly to specified cathegory
Did you remove old code from that if sentence?
- tomasgusta
16 years 11 months ago #27898
by tomasgusta
Replied by tomasgusta on topic Re: Remove menu, breadcrumb and link directly to specified cathegory
Hello Matias!
I think I did so... The lines were very close to eachother:
Here is a copy of the edited php-file:
<?php
* @version $Id: fb_layout.php 827 2009-06-09 19:53:37Z mahagr $
* Kunena Component
* @package Kunena
* @Copyright (C) 2008 - 2009 Kunena Team All rights reserved
* @license www.gnu.org/copyleft/gpl.html GNU/GPL
* @link www.kunena.com
* Based on FireBoard Component
* @Copyright (C) 2006 - 2007 Best Of Joomla All rights reserved
* @link www.bestofjoomla.com
* Based on Joomlaboard Component
* @copyright (C) 2000 - 2004 TSMF / Jan de Graaff / All Rights Reserved
* @author TSMF & Jan de Graaff
defined( '_JEXEC' ) or die('Restricted access');
* Function to print the pathway
* @param object database object
* @param object category object
* @param int the post id
* @param boolean set title
function KUNENA_print_pathway(&$kunena_db, $obj_fb_cat, $bool_set_title, $obj_post = 0) {
echo '<div class="fb_pathway">' . fb_get_pathway($kunena_db, $obj_fb_cat, $bool_set_title, $obj_post) . '</div>';
function KUNENA_get_pathway(&$kunena_db, $obj_fb_cat, $bool_set_title, $obj_post = 0)
global $fbIcons;
$document=& JFactory::getDocument();
$fbConfig =& CKunenaConfig::getInstance();
//Get the Category's parent category name for breadcrumb
$kunena_db->setQuery("SELECT name, id FROM #__fb_categories WHERE id='" . $obj_fb_cat->getParent() ."'");
$objCatParentInfo = $kunena_db->loadObject();
check_dberror("Unable to load category.");
//get the Moderator list for display
$kunena_db->setQuery("SELECT * FROM #__fb_moderation AS m LEFT JOIN #__users AS u ON u.id=m.userid WHERE m.catid='" . $obj_fb_cat->getId() . "'");
$modslist = $kunena_db->loadObjectList();
check_dberror("Unable to load moderators.");
// echo '<div class="fb_pathway">';
// List of Forums
// show folder icon
$return = '<img src="' . KUNENA_URLIMAGESPATH . 'folder.gif" border="0" alt="' . _GEN_FORUMLIST . '" style="vertical-align: middle;" /> ';
// link to List of Forum Categories
$return .= ' '.CKunenaLink::GetKunenaLink(_GEN_FORUMLIST).'<br />';
// List of Categories
if ($objCatParentInfo)
if ($bool_set_title)
$document->setTitle(stripslashes($objCatParentInfo->name) . ' - ' . stripslashes($obj_fb_cat->getName()) . ' - ' . stripslashes($fbConfig->board_title));
// show lines
$return .= ' <img src="' . KUNENA_URLIMAGESPATH . 'tree-end.gif" alt="|-" border="0" style="vertical-align: middle;" />';
$return .= ' <img src="' . KUNENA_URLIMAGESPATH . 'folder.gif" alt="' . $objCatParentInfo->name . '" border="0" style="vertical-align: middle;" /> ';
// link to Category
$return .= ' '.CKunenaLink::GetCategoryLink('listcat', $objCatParentInfo->id, $objCatParentInfo->name).'<br />';
$return .= ' <img src="' . KUNENA_URLIMAGESPATH . 'tree-blank.gif" alt="| " border="0" style="vertical-align: middle;" />';
else
$document->setTitle(stripslashes($obj_fb_cat->getName()) . ' - ' . stripslashes($fbConfig->board_title));
// Forum
// show lines
$return .= ' <img src="' . KUNENA_URLIMAGESPATH . 'folder.gif" alt="+" border="0" style="vertical-align: middle;" /> ';
// Link to forum
$return .= ' '.CKunenaLink::GetCategoryLink('showcat', $obj_fb_cat->getId(), $obj_fb_cat->getName());
//check if this forum is locked
if ($obj_fb_cat->getLocked()) {
$return .= isset($fbIcons) ? ' <img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="'
. _GEN_LOCKED_FORUM . '" title="' . _GEN_LOCKED_FORUM . '"/>' : ' <img src="' . KUNENA_URLIMAGESPATH . 'lock.gif" border="0" width="13" height="13" alt="' . _GEN_LOCKED_FORUM . '" title="' . _GEN_LOCKED_FORUM . '">';
// check if this forum is reviewed
if ($obj_fb_cat->getReview()) {
. '" border="0" alt="' . _GEN_REVIEWED . '" title="' . _GEN_REVIEWED . '"/>' : ' <img src="' . KUNENA_URLIMAGESPATH . 'review.gif" border="0" width="15" height="15" alt="' . _GEN_REVIEWED . '" title="' . _GEN_REVIEWED . '">';
//check if this forum is moderated
if ($obj_fb_cat->getModerated())
. '" border="0" alt="' . _GEN_MODERATED . '" title="' . _GEN_MODERATED . '"/>' : ' <img src="' . KUNENA_URLEMOTIONSPATH . 'moderate.gif" border="0" alt="' . _GEN_MODERATED . '" title="' . _GEN_MODERATED . '"/>';
$text = '';
if (count($modslist) > 0)
foreach ($modslist as $mod) {
$text = $text . ', ' . $mod->username;
$return .= ' (' . _GEN_MODERATORS . ': ' . ltrim($text, ",") . ')';
if ($obj_post != 0)
$document->setTitle($obj_post->subject . ' - ' . stripslashes($fbConfig->board_title));
// Topic
// show lines
$return .= '<br /> <img src="' . KUNENA_URLIMAGESPATH . 'tree-blank.gif" alt="| " border="0" style="vertical-align: middle;" />';
$return .= ' <b>' . $obj_post->subject . '</b>';
// Check if the Topic is locked?
if ((int)$obj_post->locked != 0) {
$return .= ' <img src="' . KUNENA_URLIMAGESPATH . 'lock.gif" border="0" width="13" height="13" alt="' . _GEN_LOCKED_TOPIC . '" title="' . _GEN_LOCKED_TOPIC . '"/>';
// echo '</div>';
return $return;
* Function that get the menu used in the header of our board
* @param array $fbConfig
* @param array $fbIcons
* @param int $my_id
* The user id
* @param int $type
* What kind of header do you want to print: 1: default (home/profile/latest posts/faq), 2: extended1 (home/profile/view/pending messages/faq) ,3:extended2 (home/profile/reply/view/pdf/faq)
* @param string $view
* The view the user is currently using, only needs to be pass when type=
or type==2
* @param int $catid
* Only needs to be passed when type=
or type==2
* @param int $id
or type==2
* @param int $thread
or type==2 (well actually just give 0 when type==2)
* @param boolean $is_moderator
* Only needs to be passed when type==2
* @param int $numPending
* Number of pending messages, only needs to be passed when type==2
* @return String $header
* The menu
function KUNENA_get_menu($cbitemid, $fbConfig, $fbIcons, $my_id, $type, $view = "", $catid = 0, $id = 0, $thread = 0, $is_moderator = false, $numPending = 0)
return '';
$func = strtolower(JRequest::getVar('func', ''));
if ($func == '') // Set default start page as per config settings
$func = 'showcat';
$catid = '4';
$header = '<div id="fb_topmenu" ><div id="Kunena_tab"><ul>';
$header .= '<li ';
if ($func == 'listcat' ) $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetCategoryListLink('<span>'.(array_key_exists('home', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _KUNENA_CATEGORIES . '" title="' . _KUNENA_CATEGORIES . '" />' : _KUNENA_CATEGORIES).'</span>');
$header .= '</li>';
$header .= ' <li ';
if ($func == 'latest' || $func == '') $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetShowLatestLink('<span>'.(array_key_exists('showlatest', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _KUNENA_ALL_DISCUSSIONS . '" title="' . _KUNENA_ALL_DISCUSSIONS . '"/>' : _KUNENA_ALL_DISCUSSIONS).'</span>');
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li ';
if ($func == 'mylatest') $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetShowMyLatestLink('<span>'.(array_key_exists('showmylatest', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _KUNENA_MY_DISCUSSIONS . '" title="' . _KUNENA_MY_DISCUSSIONS . '"/>' : _KUNENA_MY_DISCUSSIONS).'</span>');
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li ';
if ($func == 'myprofile' ) $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetMyProfileLink($fbConfig, $my_id, '<span>'.(array_key_exists('profile', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . '' . $fbIcons . '" border="0" alt="' . _GEN_MYPROFILE . '" title="' . _GEN_MYPROFILE . '"/>' : _GEN_MYPROFILE).'</span>');
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li ';
if ($func == 'announcement') $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetShowAnnouncement('<span>'.($fbIcons ? '<img src="' . KUNENA_URLICONSPATH . '' . $fbIcons . '" border="0" alt="' . _ANN_ANNOUNCEMENTS . '" title="' . _ANN_ANNOUNCEMENTS . '"/>' : _ANN_ANNOUNCEMENTS).'</span>');
$header .= '</li>';
$header .= ' <li ';
if ($func == 'search' || $func == '') $header .= ' class="Kunena_item_active" ';
$header .=' >'.CKunenaLink::GetShowSearch('<span>'.($fbIcons ? '<img src="' . KUNENA_URLICONSPATH . '' . $fbIcons . '" border="0" alt="' . _KUNENA_SEARCH_ADVSEARCH . '" title="' . _KUNENA_SEARCH_ADVSEARCH . '"/>' : _KUNENA_SEARCH_ADVSEARCH).'</span>');
$header .= '</li>';
switch ($type)
case 3:
//Threaded view option removed from Kunena
// if ($view == "flat") {
// $header .= '<li>';
// $header .= CKunenaLink::GetViewLink('view', $id, $catid, 'threaded', '<span>'. _GEN_THREADED_VIEW .'</span>');
// $header .= '</li>';
// else
// $header .= CKunenaLink::GetViewLink('view', $id, $catid, 'flat', '<span>'. _GEN_FLAT_VIEW .'</span>');
break;
case 2:
// $header .= CKunenaLink::GetViewLink('showcat', $id, $catid, 'threaded', '<span>'. _GEN_THREADED_VIEW .'</span>');
// else
// $header .= CKunenaLink::GetViewLink('showcat', $id, $catid, 'flat', '<span>'. _GEN_FLAT_VIEW .'</span>');
if ($is_moderator)
if ($numPending > 0)
$numcolor = '<font color="red">';
$header .= '<li>';
$header .= CKunenaLink::GetPendingMessagesLink( $catid, '<span>'.(array_key_exists('pendingmessages', $fbIcons)
? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . $numPending . ' ' . _SHOWCAT_PENDING . '" />' : $numcolor . '' . $numPending . '</font> ' . _SHOWCAT_PENDING).'</span>');
$header .= '</li>';
break;
case 1:
default:
break;
if ($fbConfig->enablerulespage)
$header .= ' <li ';
if ($func == 'rules' ) $header .= ' class="Kunena_item_active" ';
$header .= ' >'.CKunenaLink::GetRulesLink($fbConfig, '<span>'.(array_key_exists('rules', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _GEN_RULES . '" title="' . _GEN_RULES . '"/>' : _GEN_RULES).'</span>');
$header .= '</li>';
if ($fbConfig->enablehelppage)
$header .= ' <li ';
if ($func == 'faq' ) $header .= ' class="Kunena_item_active" ';
$header .= ' >'.CKunenaLink::GetHelpLink($fbConfig, '<span>'.(array_key_exists('help', $fbIcons) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons . '" border="0" alt="' . _GEN_HELP . '" title="' . _GEN_HELP . '"/>' : _GEN_HELP).'</span>');
$header .= '</li>';
$header .= '</ul></div></div>';
return $header;
function getSearchBox()
<?php
* Kunena Component
* @package Kunena
global $fbIcons;
// List of Forums
// show folder icon
// show lines
// link to Category
else
// Forum
// show lines
// Link to forum
$text = '';
if ($obj_post != 0)
// Topic
// show lines
// echo '</div>';
return $return;
* @param int $my_id
* The user id
* @param int $type
or type==2* @param int $catid
or type==2* @param int $id
or type==2* @param int $thread
or type==2 (well actually just give 0 when type==2)* @param boolean $is_moderator
* The menu
return '';
$func = 'showcat';
$catid = '4';
$header .= '<li ';
$header .= '</li>';
$header .= ' <li ';
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li ';
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li ';
$header .= '</li>';
if ($my_id != 0)
$header .= ' <li ';
$header .= '</li>';
$header .= ' <li ';
$header .= '</li>';
switch ($type)
case 3:
// else
break;
case 2:
// else
if ($is_moderator)
$header .= '<li>';
$header .= '</li>';
break;
case 1:
default:
break;
$header .= ' <li ';
$header .= '</li>';
$header .= ' <li ';
$header .= '</li>';
return $header;
15 years 8 months ago #77861
by Superbad
Replied by Superbad on topic Re: Remove menu, breadcrumb and link directly to specified cathegory
i don't have an fb_layout.php file in my kunena component?
Time to create page: 0.237 seconds
