Question Remove menu, breadcrumb and link directly to specified cathegory
17 years 3 months ago - 17 years 3 months ago #27646 by tomasgusta
Hello!
Kunena is really a fantastic tool! A bit tricky in the beginning thought...
Could anyone take a look at my forum at "medicinhistoria.nu" forum-button?
First, I would like that the forum button linked directly to the cathegory "Medicinhistorisk diskussion". I tried to do it as an external link, but the page disapeared when I removed the old link.
For the second I would like to remove the "kategorier, senaste diskussioner, avancerad sökning"-meny.
And finally I would like to remove the breadcrumb with the arrow from the little house.
Is this possible to do?
Best regards Tomas
Last edit: 17 years 3 months ago by tomasgusta.
17 years 3 months ago #27653 by Matias
You need to do some manual coding in order to change default page and to remove kunena menu.
Menu can be hidden by disabling function call in your template:
fb_layout.php, around line 170 there is something like this:
function KUNENA_get_menu($cbitemid, $fbConfig, $fbIcons, $my_id, $type, $view = "", $catid = 0, $id = 0, $thread = 0, $is_moderator = false, $numPending = 0) { $func = strtolower(JRequest::getCmd('func', '')); if ($func == '') // Set default as per config settings {
Just add
return '';
in the beginning of that function:
function KUNENA_get_menu($cbitemid, $fbConfig, $fbIcons, $my_id, $type, $view = "", $catid = 0, $id = 0, $thread = 0, $is_moderator = false, $numPending = 0) { return ''; $func = strtolower(JRequest::getCmd('func', '')); if ($func == '') // Set default as per config settings {
To point into your main category (if there will be no other main categories!) you need to change line 307-320 from:
if ($func == '') // Set default start page as per config settings { switch ($fbConfig->fbdefaultpage) { case 'recent': $func = 'latest'; break; case 'my': $func = $kunena_my->id > 0 ? 'mylatest' : 'latest'; break; default: $func = 'listcat'; } }
to:
if ($func == '') // Set default start page as per config settings { $func = 'showcat'; $catid = YOUR_CATEGORY_ID_HERE; }
It should work..
For the breadcrumb look at fb_pathway.php file. It lists the path to current forum/action. Calling return in the beginning of the code should remove most of it..
17 years 3 months ago #27762 by tomasgusta
Thank you very much Matias!
With your help I managed to remove the meny "category, advanced..." and the breadcrumbs. Unfortunately, the forum doesn't start inside the category of my choice.
I use a template called "we love kunena". The two lines you gave the advice to change is right next to each other at line 170:
return '';
$func = strtolower(JRequest::getVar('func', ''));
$func = 'showcat';
$catid = 4;
Still the forum won't start inside category 4. Have I written the forum id in a false way?
Best regards Tomas
17 years 3 months ago #27768 by 810
try
$catid = '4';
Regards
810
17 years 3 months ago - 17 years 3 months ago #27775 by tomasgusta
Hi 810!
I tried to change the line to:
$catid = '4';
but the forum still starts up in the main forum "medicinhistoriskt forum":
17 years 3 months ago - 17 years 2 months ago #27776 by tomasgusta
Instead I would like it to start inside the category "medicinhistorisk diskussion" as in this link:
medicinhistoria.nu/index.php/forum/4-med...historisk-diskussion
What can be wrong?
Best regards Tomas
Last edit: 17 years 2 months ago by tomasgusta.
Time to create page: 0.146 seconds
