Question Community Builder login and register
17 years 4 months ago #23156 by chema
Ok!! my friend,
For any question about community builder always help!!
Regards
DJ!! and KS!! Team
17 years 4 months ago #23820 by carsten888
@chema
thank you!
17 years 4 months ago #23827 by Gigameister
hi, i have a similar problem, my template uses a ja_login module for the current login scheme, but if i try to put cb_login there (with captcha protection) it just looks static and ugly, i would really appreciate some help with this.
thank you
17 years 4 months ago #23838 by chema
hi Gigameister,
I need a link or screenshot for view your problem,thanks.
@carsten888, thanks for you.
Regards.
DJ!! and KS!! Team
17 years 4 months ago #23840 by Gigameister
www.FAtuga.net - if i put the normal login in ja_login position it works perfect, if i use CB it just, well, check for yourself... =(
17 years 4 months ago #23841 by chema
Disable the default login and put the module community builder in the position ja_login as this:
In configuration module_cb:
- Module orientation --> Horizontal
- Display tipe --> Compact
Put images for registration and lost password.
view example:
test...
Regards.
DJ!! and KS!! Team
