Question Community Builder login and register
17 years 2 months ago #22823 by the_ai
Hey there! I have problems with several accounts posting spam. I've disabled them through community builder(banned them). But as I see the login button in the forum leads to the standard joomla component user and not to something from community builder.
I have chosen community builder profiles in the backend of kunena, but this is not effecting those 2 buttons(login and register) - is there something that I have to configure out there, or the best thing is to wait for a code fix, or to remove these things from my template?
Here is an example
compojoom.com/forum.html
Click on login, password reset or register.
17 years 2 months ago #22851 by Lintzy
17 years 2 months ago #22858 by the_ai
compojoom.com/component/comprofiler/registers.html
The CB module handles the registration process. So the link in the forum should lead to the forum and not to the default joomla user component. I guess I should replace the text from the forum with my CB module, then it would be fine.
17 years 2 months ago #22860 by Lintzy
This plugin works with Community Builder 1.2
17 years 2 months ago #22877 by chema
@the_ai you can also in /components/com_kunena/template/default/plugin/profilebox/profilebox.php:
Search:
<?php // AFTER LOGIN AREA if ($fbConfig->fb_profile == 'cb') { $loginlink = CKunenaCBProfile::getLoginURL(); $logoutlink = CKunenaCBProfile::getLogoutURL(); $registerlink = CKunenaCBProfile::getRegisterURL(); $lostpasslink = CKunenaCBProfile::getLostPasswordURL(); } else { $loginlink = JRoute::_('index.php?option=com_user&amp;view=login'); $logoutlink = JRoute::_('index.php?option=com_user&amp;view=login'); $registerlink = JRoute::_('index.php?option=com_user&amp;task=register&amp;Itemid=' . $Itemid); $lostpasslink = JRoute::_('index.php?option=com_user&amp;view=reset&amp;Itemid=' . $Itemid); } if ($kunena_my->id) { ?>
Replace for:
<?php // AFTER LOGIN AREA if ($fbConfig->fb_profile == 'cb') { $loginlink = CKunenaCBProfile::getLoginURL(); $logoutlink = CKunenaCBProfile::getLogoutURL(); $registerlink = CKunenaCBProfile::getRegisterURL(); $lostpasslink = CKunenaCBProfile::getLostPasswordURL(); } else { $loginlink = JRoute::_('index.php?option=com_comprofiler&amp;task=login'); $logoutlink = JRoute::_('index.php?option=com_comprofiler&amp;task=logout'); $registerlink = JRoute::_('index.php?option=com_comprofiler&amp;task=registers'); $lostpasslink = JRoute::_('index.php?option=com_comprofiler&amp;task=lostPassword'); } if ($kunena_my->id) { ?>
This work fine for registration on community builder since "from" kunena.
Regards.
DJ!! and KS!! Team
17 years 2 months ago #22878 by the_ai
Thank you chema!
That worked!
Time to create page: 0.222 seconds
