Question can't believe there is not LATEST module for 1.5
If you know all that your described above about the javascript library, then you should post a well described support for it, including instructions on how to make those joomla templates compatibles with your 1.6 kunena.
also, as I stated 2 post before, there are other issues (yes probably also due to this java problem) for example, not able to use bbcode, menus, smilies, editing profile...
Thanks.
www.friendlyphotozone.com
thanks.
GoremanX wrote: Well yes actually, I can use use all those features. See, I read the relevant documents in the Documentation section of this site that explained:
- the requirements for running Kunena 1.6: docs.kunena.org/index.php/K_1.6_Technical_Requirements
- the Mootools compatibility requirements: docs.kunena.org/index.php/Mootools_1.2.4_%28Part_1%29 and docs.kunena.org/index.php/Mootools_1.2.4_%28Part_2%29
Sounds to me like you're having the Mootools issue.
I have read that documentation and applied but nothing, I mean, the 1.6 gets installed but many features just dont work, editing profile for example.
I have enabled Mootools update plugin, but nothing happens.
so now I am with k1.5
What is the normal procedure to upgrade from 1.5.13 to 1.6?
have to uninstall first or just install it over.?
and when should I enable Mootools upgrade plugin? after or before install 1.6?
thanks
