Question Smiles/Emoticons question
16 years 5 months ago - 16 years 5 months ago #50968 by Horus
Replied by Horus on topic Re: Smiles/Emoticons question
Hi again Sozzled. Thanks again, i see that DTP 2 have did just that. But i will whait for that answer too. There is no point using theese as emoticons, if i will place them whit img tags in posts.
If it is, as you say a defect, i will use emty emoticon, for free space, between the words.
Last edit: 16 years 5 months ago by Horus.
16 years 4 months ago - 16 years 4 months ago #51169 by Horus
Hello again, i was able to successfuly implement emty space between smiles, using empy file for the free space. However i would like to ask once more, for that annoyng code that appear instead of some smiles. First image show the result, and second one, show what is in the editor.
Last edit: 16 years 4 months ago by Horus.
16 years 4 months ago #51193 by Horus
someone? It is realy important to me!
16 years 4 months ago #51198 by Cerberus
ok i have been watching this topicas it unfolded and seems to be to be a pointless thing to be trying to do but there we go that my opinion.
ok now on to your issue it would seem to me that in your attempt to add space between your emoticons you have completely corrupted the code for them and as a result when you add an emoticon you are also show some php code from the file that creates the message page.
so i would say start from scratch again so that the error you have created is fixed and then edit each smilie and add abit of transparent canvas either side of them using a program like GIMP or PHOTOSHOP then you will gain your empty space and loose the other error that is caused by the other way you tried to achieve this. When trying to do things like this with kunena you should always remember the quote below,
Sozzled quote: KISS - keep it simple stupid
theres is always 2 way to achieve a result the easy way and the hard way.
16 years 4 months ago - 16 years 4 months ago #51203 by Horus
Hi Cerberus, i do not uderstand how can i corrupt the code?! I have done nothing but to uploading some png files and point the grey files in a database, there was no any messing whith code here. I am adding space, just like i am adding another smile.
You'r suggestion to deleete old, and start from the beggining, could be acceptable, but adding space in the smile-file has no point. Because i need this space to seperate the words that i am typing, whit theese smiles. Like the picture from below:
Two more things: that code appear randomly, i have seen it before i even realized, that i need to add a free space.There is a screen for it, in the begining of that topic here. And, thanks for the attention, i am thankful!
16 years 4 months ago #51204 by Horus
But i have to say, that this code, have not seem to appear in the old emoticons, it is shown just in theese that i add.
