- Thank you received: 71
Question Smiles/Emoticons question
Multiple [breaking] spaces are compressed to a single space; that's normal behaviour for web browsers. That's why I wanted to suggest using non-breaking spaces earlier in this discussion, but Kunena doesn't support the HTML code ... and that killed off that suggestion.ok seems silly to me but can you not just type a space in the text if its text you are try to space out or maybe if your a russian only forum ( im guessing that russian ) maybe the devs here can sudjest maybe a way to do this by editing the php code. I dont even know if kunena support the russian language, again maybe teh devs can answer that.
Thereisnodifferenceifitypethislikethat or l i k e t h a t m y f r i e n d
The space that i use empty smile for, it works fine, and the hack is doing a diferent thing that i do not need to use. I know the answer of my question, but i just can not find where i can change the code, i just can not find the code that is shown in firebug. It is probably in some php file, but i already search in most of them in components/kom_kunena.
None of these ideas are really solutions; they're all workarounds. The ideal solution is to employ a hieroglyphic font (if one exists), that your users can access, that has proportional spacing/kerning between the characters. The complications lie in (a) deploying this font face to your users; and (b) enabling Kunena to use an alternative font within parts of your messages. :S
