This is not a support forum for sh404SEF or its related products. For sh404SEF support you should visit sh404SEF .
The information given in this category is intended to guide users who want to use sh404SEF with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of sh404SEF.
Important Pagination not working
12 years 3 months ago #158069 by buxshots
Replied by buxshots on topic Pagination not working
all kunena links removed. Still the same :(
12 years 3 months ago #158070 by 810
Replied by 810 on topic Pagination not working
then try disable sh404sef. and clean cache again
12 years 3 months ago #158071 by 810
maybe its the forum menu.
Go to backend- kunena - tools - menu - fix menu.
Then move the forum item to your menu (top ?)
because I see: wf-menu-profiles/forum that's incorrect sef
12 years 3 months ago - 12 years 3 months ago #158072 by buxshots
Fixed the menu and completely deactivated sh404sef. This did the trick!!!
Then it works until I activate sh404sef again. Mysterious, because kunena is deactivated in sh404sef so this should not affect kunena... unfortunately I cannot deactivate sh404sef so I will need to ask their support to fix this issue...
Thanks so much for your apprediated effort
Last edit: 12 years 3 months ago by buxshots.
12 years 3 months ago #158076 by 810
12 years 3 months ago #158155 by Matias
Replied by Matias on topic Pagination not working
Kunena remembers the page on the menu items, which means that if you get back to the recent list (for example) it will not get into the first page, but the page you visited the last time. This allows users to navigate more quickly in Kunena as if you were on page 3, that's probably the page you want to get back.
But in order to do that we have had to add limitstart=0 to the pagination, which is usually not in there. Looks like sh404SEF is finding it redundant and removing it as something that's not needed.
You may want to talk about this with sh404SEF developer and explain what is happening. It also looks that I need to find another way to do this, but it's not going to happen for Kunena 3.0 for sure as it breaks backwards compatibility.
