This is not a support forum for sh404SEF or its related products. For sh404SEF support you should visit sh404SEF .
The information given in this category is intended to guide users who want to use sh404SEF with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of sh404SEF.
Important Pagination not working
12 years 3 months ago #158180 by 810
Replied by 810 on topic Pagination not working
Ok, found the problem.
There is a bug in sh404sef:
Fatal error: Access to undeclared static property: KunenaRoute::$current in \administrator\components\com_sh404sef\classes\router.php on line 253
So comment out the line. then its working again.
Regards 810
12 years 3 months ago - 12 years 3 months ago #158578 by slomuscio
Replied by slomuscio on topic Pagination not working
After several hour of testing I've found a simple solution for this problem:
1. deactivate joomla sef
2. activate sh404sef and set the default for kunena component in the sh404sef / configuration / sh404sef configuration / components ->> set kunena as Normal , overright sef (as other components configuration)
3. create a new url in sh404sef url menu as follows:
sef_url: first-forum-page.html
non Sef url: index.php?option=com_kunena&view=category&catid=2&Itemid=104&limitstart=0
Save the configuration, clear all urls and your browser cache. Now the pagination problem to the first page is solved by means of a new link to first-forum-page.html
Sebastiano
Last edit: 12 years 3 months ago by slomuscio.
9 years 5 months ago #186746 by orussier
Replied by orussier on topic Pagination not working
i've the same problem : KUNENA pagination is not working because the limitstart=0 is not present into the url.
And then, it's always the last page that is selected and I would to start with the first page.
Do you have resolved this issue ?
It seems that the "?limistart=0" is missing inside url. How to add it on the different Kuena links ?
I use Joomla 3.7.2 and Kunena 5.0.10-DEV. I've desactivad SEA on Joomla and Kunena. I don't use SH404SEF.
In advance, thanks a lot
Olivier
