This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Solved Author is not shown... (but recognised).
5 years 6 months ago #217260 by gboy
FIrst and lastname work perfectly fine.
My issue is if I choose "First name" and "lastname intial" or vice versa they don't render.
what I am trying to accomplish is to use the "First name" and "Initial" of the "lastname" plus add another custom field that I have made to attach at the end with the Custom setting.
I can get the firstname lastname and custom field to work but not the firstname Intial from lastname plus custom field.
In either case I think I should be able to come up with something else that would be suitable.
Thanks again for your time.
5 years 6 months ago #217273 by rich
In principle, I don't know the Community Builder, because I've installed this extension only for tests.
Maybe you get more suggestions in the Joomlapolis forum .
